Water Pump replacement....ugh!
Old May 6, 2010 | 04:41 PM
jax996's Avatar
jax996 is infamous around these parts
My mechanic just told me that my water pump is starting to go, I have 30,000 miles on my car. Quick questions:
1. Is this semi normal? If so, is there any preventative maintenance that can be done?
2. He quoted me about $340 for the pump and three hours of labor. Does this sound about right or am I getting hosed?
Thanks!!!
Old May 6, 2010 | 05:09 PM
HxCforlife's Avatar
Awaiting Email Confirmation
HxCforlife has a spectacular aura aboutHxCforlife has a spectacular aura about
If you are handy you can change it yourself. I changed mine a few months ago,it's a ***** getting it in and out but worth it saving a labor charge.There is a great DIY on renntech.org . Also Suncoast Porsche has the pump for $225.00 with the gasket.
Old May 6, 2010 | 05:29 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
You can get an OEM pump for less than $200, sometimes as little at $100. Search Ebay, in particular Deutchepartsusa.
http://cgi.ebay.com/ebaymotors/Porsc...Q5fAccessories
There are 20 or more listed right now. Remember you will need a new gasket if one is not included. You might want to consider one with a metal impeller, the stock one has a plastic impeller and these tend to wear/break faster.
I got mine on line in a Porsche box for about $100.
Old May 6, 2010 | 06:08 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
That's a great price for OEM's. Just make sure you get the metal impellers.
3 hours labor is about right. Only at 30k? I don't think that's normal but if it indeed is leaking, get it replaced. My boxster's totally failed around 75k and 911 was fine over 100k but just replaced it just for the heck of it.
pwdrhound
Sep 13, 2016 10:44 AM
proTUNING Freaks
Oct 13, 2015 08:12 PM
Wheeler
Sep 22, 2015 08:02 PM
carbonjim996TT
Sep 20, 2015 08:14 AM
