Help. Strange exhaust noise from my 996 with PSE
Old Jun 7, 2010 | 11:38 PM
yellowbmr's Avatar
yellowbmr is just really niceyellowbmr is just really niceyellowbmr is just really niceyellowbmr is just really niceyellowbmr is just really nice
I have noticed this strange exhaust noise / rattle for the past few months. Just got the car back from mechanic in Lake Forest (Hergeshemier) for the 60k service and they could not find anything.
It's very noticable when driving cold and also even more noticable when driving close to buildings/homes. It sounds like I have a exhaust leak. Sometimes like a harley davidson kind of sound.
I tried rubber hammering the cats with engine cold to hear any loose sound, but nothing.
Is it time for dealership?
Has anyone heard this symptom before? Do PSE's go bad?
Open for suggestions.
Old Jun 8, 2010 | 09:03 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
Could be a baffle inside the muffler coming lose.
Old Jun 9, 2010 | 05:05 AM
tonybony123's Avatar
tonybony123 is infamous around these parts
tonybony
i dont know if its the same rattle, but i have a 996 2001 with twin exhausts and apperently there is a flap inside each pipe that is active when the engine is cold and it does rattle audably but when the engine is warmed up the flaps stop opperating and the rattle stops, this is all quite normal
Old Jun 9, 2010 | 09:15 AM
Sosoomi1's Avatar
Sosoomi1 is a jewel in the roughSosoomi1 is a jewel in the roughSosoomi1 is a jewel in the rough
I kinna like that rattle....
Old Jun 9, 2010 | 10:50 AM
prsdoc's Avatar
prsdoc is infamous around these parts
I'd agree with the above comments; likely the baffles in the PSE.
Have you tried disengaging the PSE baffles? Meaning if your system has active baffles, (quiet between 25-40 mph) rather than wide open loud all the time.
Try this link:
http://www.renntech.org/forums/index.php?showtopic=2470
Old Jun 15, 2010 | 12:45 AM
yellowbmr's Avatar
I don't have a switch to override the baffles. Is it something that could be removed by dealer? Mine was apparently set to wide open since i don't have the wiring to the front of the car.
Please tell me why baffles have gone bad after 30k? how easy is it to fix this baffle issue?
Old Jun 15, 2010 | 01:43 AM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
The default on the PSE is open/loud. It takes vacuum lines, a change over valve and switches to have an "active" PSE (by the way there is a setup for this for sale right now by an owner on Rennlist). If ou don't have the system to switch over the PSE than by default it is always open/loud.
Baffles coming loose in the 996 mufflers, either stock or PSE, is not uncommon.
Old Jun 15, 2010 | 10:55 AM
BigDaddy's Avatar
BigDaddy is infamous around these partsBigDaddy is infamous around these parts
Hey,
some guys here in germany open their PSE and then they make some welding points inside the muffler...after that no more noise in those mufflers !!
Greetz....
Old Jun 22, 2010 | 12:28 AM
yellowbmr's Avatar
This is strange. This week I made an appointment to take the car to dealer. (I have extended warranty). But today I noticed the noise is gone. ???
Did the baffle come loose and exit through the exhaust? Or is it stuck in a position now that doesn't make the noise?
I am puzzled.
Old Sep 27, 2010 | 01:46 PM
SAZ's Avatar
SAZ
SAZ is infamous around these parts
2004 996 4s. problem was cats. had both replaced under warranty. 24k miles.
Old Jan 26, 2011 | 08:48 PM
yellowbmr's Avatar
Update:I replaced the driver side PSE muffler with factory exhaust that I had in storage and the noise/rattle is gone.
I did some research and found out that Darin at FDMotorsport has seen this problem with loose baffles. He asked me to send the exhaust to him so he can weld the part that comes loose. I hope to get it back soon, cause the stock muffler sound doesn't do justice.
Old Jan 26, 2011 | 08:54 PM
Dennis C's Avatar
I had the same issue at about 70K miles. My cats were replaced and the rattle stopped.
Old Jan 27, 2011 | 08:43 AM
tarzancoe's Avatar
tarzancoe is infamous around these parts
7k worth of mufflers these days, and they fail. Nice, Porsche.
Old Jan 27, 2011 | 09:01 AM
tarzancoe's Avatar
Link pls ? couldn't' t find it
Old Jan 28, 2011 | 01:18 PM
RF5BPilot's Avatar
RF5BPilot is just really niceRF5BPilot is just really niceRF5BPilot is just really niceRF5BPilot is just really niceRF5BPilot is just really nice
When I first saw the heading, I thought we were going to have to tell you that was your engine you were hearing for the first time.
