Need help with wheel compatibility
Old Jul 9, 2010 | 07:23 AM
flybye's Avatar
flybye is infamous around these parts
Hi, I just bought my first Porsche, a 2001 Carrera and was offered wheels off of a 2004 996 Turbo. Was wondering if it will fit. I know nothing about offsets, backspacing, etc... Please advise.
Old Jul 9, 2010 | 07:34 AM
Zen911's Avatar
Zen911 is infamous around these parts
If you just got a Carrera (not a 4s) its narrow body and the turbo is wide body so I believe they would stick out past the fender. I may be wrong though so wait till someone else answers you.
Old Jul 9, 2010 | 08:10 AM
flybye's Avatar
re:wheel specs
The wheel offered to me is 19x11 rear. Checking tirerack.com, they do offer that size(max) for my vehicle, but again, the question is regarding the offset. I believe the bolt pattern is the same at 5-130.
Old Jul 9, 2010 | 12:50 PM
FLY996's Avatar
FLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud of
Wrong offset...will not fit...
Old Jul 10, 2010 | 08:50 AM
Brando's Avatar
Brando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud of
Cool
I know that they are wide body offsets.....but I wonder what it would actually look like?
The stock wheel offsets are so conservative and tucked in, you can run a 15mm spacer with no problem.
You need to actally try one on.
Zero911
Aug 24, 2015 06:51 PM
ModBargains
Aug 20, 2015 12:28 PM
