Engine stalls at high speed
Old Sep 25, 2010 | 10:43 AM
Ken7258's Avatar
Ken7258 is a jewel in the roughKen7258 is a jewel in the roughKen7258 is a jewel in the roughKen7258 is a jewel in the rough
This has been happening for years. I have a 01 996 C2 Tip. It use to just happen on the track with less then 1/2 tank of gas. Car would stall for 1-2 seconds then start running again. It's just like the ignition was turned off and back on. I now always track the car with at least 1/2 tank of gas. I replaced the fuel filter last month and everything has been fine. I was at the track last weekend, no stalling, then on the way home with over 1/2 tank of gas, I was stalling every 30 seconds for 2-3 seconds then the car would start running again. It's just like the ignition was turned off, wait 2-3 seconds and then turn it back on. I filled up the tank and no problems.
Could there be any problems with fuel pump lines. I know there are all type of lines coming and going from the fuel pump and maybe some have broken free and with less then a full tank of gas they are getting some type of vapor lock. Thanks for your help.
Old Sep 25, 2010 | 10:56 AM
GT3 Chuck's Avatar
Administrator
there is a little curved hose on the top of the fuel pump assembly that is a common problem...when your fuel level gets low that hose could be sucking air and causing your loss of fuel...do a search..I think you will find more info
Old Sep 25, 2010 | 11:13 AM
Ken7258's Avatar
Can just this hose be replaced or does the whole fuel pump with all hoses need to be replace? Since the car is 9 years old, maybe time to replace the complete fuel pump. Thanks for your help.
Old Sep 25, 2010 | 11:34 AM
GT3 Chuck's Avatar
Administrator
that may be a good idea while you are in there, especially if you are paying someone to do it....but the hose can be replaced by itself...here is the culprit...
Jun 10, 2017 07:45 PM
turbotuner20v
Sep 11, 2015 12:02 PM
PelicanParts.com
Sep 1, 2015 02:36 PM
The Oss
Aug 24, 2015 08:19 PM
