engine not responding well
Old Oct 9, 2010 | 02:21 AM
rrdralli's Avatar
rrdralli is infamous around these parts
lately i've been having this problem with acceleration. if u put heavy gas, the car hesitates to rev or sometimes have no power and has a bubbling sound. but if you release the pedal and gas it back or play with the pedal it will gradually gain revs. MAF sensor, coil pack gone bad?
Old Oct 9, 2010 | 06:12 AM
chsu74's Avatar
chsu74 is infamous around these parts
clean the throttle body.
Old Oct 9, 2010 | 10:17 AM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
It could also be the fuel filter. How many miles on the car?
Old Oct 9, 2010 | 10:33 AM
Slider's Avatar
It could be as simple as 1 bad coil. The last time it happened to me, I fiddled with the gas pedal (while it was happening) to make it worse (yep - worse). At that point the car gave me a code. The code told me which pack was bad (misfile cylinder #). I replaced that coil and everything was wonderful once again. Diagnosis is really tough if you don't have a code to work from.
Old Oct 11, 2010 | 08:41 AM
gsieck's Avatar
gsieck is infamous around these parts
I had a similar issue in my 99 C2. The problem as the potentiometer and MAF
Old Oct 11, 2010 | 11:46 AM
rrdralli's Avatar
car has 43K miles. i will swap over my friend's MAF and see if that's the problem. I thought about the fuel filter before so I'll change that aswell and go on from there. the engine is healthy just power not coming through.
cnebrask
Oct 3, 2024 08:19 PM
Jul 29, 2019 11:13 AM
OldBoldPilot
Aug 26, 2015 01:12 PM
