Oil Leak photo, question
Old Dec 5, 2010 | 10:08 AM
Cheekyguille's Avatar
Cheekyguille is infamous around these parts
Heya guys, thanks in advance if you can help.
So I changed the oil on my 2003 996 and the oil changing station service guy tells me that the alum oil plug is stripped and that they won't be able to apply the recommended torque. Sure as s... I get a slow leak. Question I have is do you know how I can get this replacement part without having a Dealer/Mechanic tell me that they need to inspect because it could be something else $$$
Thanks in advance
Old Dec 5, 2010 | 10:25 AM
gu9cci's Avatar
gu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond repute
go to your local dealer and buy new plug.problem is that you need drain the oil again and refil.or suncoast parts have new plug for $4 i think.
Not big problem but your mechanic shut tell you that is strip before he put it back.That way you just pickup new one at your dealer and everythink is ok.
Old Dec 5, 2010 | 10:40 AM
putput6's Avatar
putput6 is infamous around these parts
1234
Old Dec 5, 2010 | 04:34 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
OK, is it the Hex drive that is stripped of the threads into the oil pan?
Old Dec 5, 2010 | 06:05 PM
It is the Hex that is stripped
already ordered the part, THX!
Old Dec 5, 2010 | 08:56 PM
Dharn55's Avatar
Glad to hear it is the hex, that is a no brainer to fix. If the oil is new just drain it in to a clean container and reuse it.
Jul 29, 2019 11:13 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
Senatorblutarsky
Aug 28, 2015 12:44 PM
gulf gt
Aug 27, 2015 10:27 AM
