quick oil question
Old Dec 6, 2010 | 06:27 PM
ohdavey6286's Avatar
ohdavey6286 is infamous around these parts
quick oil question
my car is down a bit according to the meter and I was wondering if I go to the store and can't find 0w40 would it be ok to put in 1.5 quarts m1 10w40 or 5w40
Old Dec 6, 2010 | 06:36 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
No problem. You sure you'll need additional 1.5q's though? That's a lot.
Old Dec 6, 2010 | 09:46 PM
fourempties's Avatar
fourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond repute
Check the dipstick! You shouldn't trust the digital meter.
Old Dec 7, 2010 | 06:25 AM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
Either one is fine but i would out it 5w40. What temp zone are you in?
Old Dec 7, 2010 | 07:01 PM
02TX996Cab's Avatar
02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold
Either is fine. With so much 0W40 already in the car (8+ quarts, even if you're 1-1/2 quarts low), the resulting blend will still be very close to 0W40.
I do recommend that you use the same brand and product line (i.e. Mobil1 5W40 if you already have Mobil1 0W40 in your car), if you can. Using the same brand/product line minimizes any chance of incompatibility.
(FYI, I blend oils regularly in my '02 Cab with zero issues.)
Old Dec 7, 2010 | 08:39 PM
jacksonporsche's Avatar
jacksonporsche is a jewel in the roughjacksonporsche is a jewel in the roughjacksonporsche is a jewel in the roughjacksonporsche is a jewel in the rough
I tried my computer knowing the oil was full and the engine was cool. the computer indicated it needed oil. pull the dipstick.
Jul 29, 2019 11:13 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
