What is wrong with my engine
Old Dec 30, 2010 | 02:46 PM
rrdralli's Avatar
rrdralli is infamous around these parts
I have a gas hesitation issue and i noticed it was my MAF, so I changed it and engine revs great but car cannot idle and dies. I've tried pulling the battery to reset but same issue. ICV ?
Old Dec 30, 2010 | 07:49 PM
DaveFL1976's Avatar
DaveFL1976 is infamous around these parts
Any chance you were a bonehead like me and replaced your MAF in the dark, only to install it 180-degrees wrong? That's what I did. The car would not idle when it was cold. Turned the MAF around correctly and viola!
It's worth checking.
Old Jan 2, 2011 | 04:05 PM
rrdralli's Avatar
thanks for the info. I did check it out but no matter what I do, car just dies. If u can keep the RPM up enough the car runs fine but once u let go of the throttle, it will drop rpms and quit. havn't figured out why. my only guess was the IDLING CONTROL VAVLE.
Old Jan 2, 2011 | 04:08 PM
boochook's Avatar
boochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond repute
Can you turn up the heat or AC and does it idle, if so, u could be right and is the ICV perhaps.
tropicatango
Jun 8, 2025 01:00 PM
Jul 29, 2019 11:13 AM
gulf gt
Aug 27, 2015 10:27 AM
Zero911
Aug 24, 2015 06:51 PM
richard2966
Bentley
Aug 22, 2015 03:33 PM
