Coolant Leak
Old Apr 1, 2011 | 03:49 PM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
Coolant Leak
I have a coolant leak and I can't tell where is is coming from. It is on the drivers side on the car. Looks to be inbetween the engine and transmission area
Here are two pics.
Closer view.
As always thank for the help.
Could in be the coolant tank. From the top it does not look like that is leaking.
Is there a coolant hose or clamp up in that area?
Old Apr 1, 2011 | 04:20 PM
GT3 Chuck's Avatar
Administrator
the tanks commonly develop hairline cracks...likely cause
Old Apr 1, 2011 | 04:44 PM
function12's Avatar
Coolant tank is toward the back of the engine compartment. This looks to be at the other end of the engine.
Old Apr 1, 2011 | 05:25 PM
GT3 Chuck's Avatar
Administrator
that is only the part of the tank that you can see...the rest of it goes pretty far back and leaks there can migrate and make you think they are coming from somewhere else...there are plenty of coolant lines and small hoses too so you will probably need to take it to someone experienced that can diagnose the problem
Glasgo
Nov 30, 2015 02:37 PM
freddiemac
Oct 7, 2015 11:05 AM
flewis763
Oct 4, 2015 04:14 PM
