Not the normal IMS or RMS oil leak.
Old May 10, 2011 | 07:34 PM
BostonCarrera4S's Avatar
BostonCarrera4S is just really niceBostonCarrera4S is just really niceBostonCarrera4S is just really niceBostonCarrera4S is just really nice
Here is the quote I got today. Need to know if this looks reasonable.
Old May 11, 2011 | 04:31 AM
GREERJ1's Avatar
GREERJ1 is infamous around these parts
Where is this being done? The IMS seal and RMS should be done with the engine "in" the car and just the tranny out. This should cost the same as a clutch job without the clutch. With the tranny out, the AOS is extremely accessible. Sending a PM.
Old May 11, 2011 | 04:44 AM
It's not leaking from the IMS or RMS. It's leaking from the vent pipe and in order to get at the pipes, the engine has to be dropped. It's also leaking coolant from the water hose.
Old May 11, 2011 | 07:56 AM
fast996's Avatar
fast996 is infamous around these parts
is your model a Tip? is that why theyre saying you have to drop the motor? thats a big quote for the AOS , id get another quote or diy
Old May 11, 2011 | 08:22 AM
I got a manual transmission. Is an engine drop needed for these repairs?
Old May 15, 2011 | 10:08 AM
Optical TDI's Avatar
Optical TDI is infamous around these parts
Yikes...better do the LN IMSB replacement if you are going to all of that trouble for the AOS. It's possible to do the AOS without removing the engine or tranny. There's a DIY on Renntech.
Old May 15, 2011 | 10:47 AM
The AOS isn't the problem here. Just figured to do it as well. There is an oil leak from the vent pipes that lead to the oil seperator.
ECS Tuning - VW
Sep 8, 2015 01:34 PM
AuZZie
Sep 2, 2015 04:26 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
