Battery draining when car is parked
Old Dec 3, 2011 | 04:13 PM
DCGearhead29's Avatar
DCGearhead29 is infamous around these parts
Hey guys, wanted some input on a battery issue I'm having. It appears that while my car sits, something is drawing a steady 3 amps off the battery. Any ideas? I know the 996 has issues with keeping a charge but is this normal?
Old Dec 3, 2011 | 04:26 PM
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
3 Amp??
Nope... your car will burst in flames any minute now unless you have a 2 KW Amplifier pushing 3000 Watt speakers blaring.
Old Dec 3, 2011 | 04:57 PM
I'm assuming it was amps, I used a AAA battery tester to check for any draw when the car was off and it read 3.2A. Wrong unit of measure??
Old Dec 3, 2011 | 05:20 PM
hroussard's Avatar
Amps
What did you try to measure and where did you put the meter?? Your car should only consume a fraction of that when parked but perhaps you looked at the wrong dial increments. They are very busy to read sometimes.
Old Dec 3, 2011 | 10:08 PM
Slider's Avatar
If it was drawing 3 amps, it wouldn't start if you parked it overnight. Having said that, these cars are pigs when they are turned off. I've started charging the battery once a week just to make sure the battery stays in top shape.
Old Dec 4, 2011 | 05:15 PM
hpuck's Avatar
hpuck is infamous around these parts
Boomerang or LoJack installed could be the culprit.
Old Dec 4, 2011 | 08:22 PM
That's the problem - it's dying overnight. It's not equipped with Lojack or Boomerang. The previous owner had installed a battery tender which is hardwired into the battery harness which I'm wondering if it could be the culprit.
I'm measuring from the battery posts when the car is off. I'm out of ideas.....
Old Dec 4, 2011 | 10:28 PM
Slider's Avatar
I guess you need to start pulling fuses... Get wifey ti watch the ammeter while you pull one by one. It should be pretty evident when you get the right one.
pwdrhound
Sep 16, 2021 02:27 PM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
DSCOFF
Aug 23, 2015 01:22 PM
Lucid Moment
Aug 20, 2015 02:22 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
