Porsche 2000 911 oil leak
Old Dec 11, 2011 | 12:41 PM
Frankb914's Avatar
Frankb914 is infamous around these parts
The car has 22k miles, I recently noticed an infrequent oil drip on the driver side a few inches in front of the exhaust, it will drip a few drops on thr floor forming a quater size circle after a run and then stop. The oil is clean. Any ideas?
Old Dec 11, 2011 | 02:37 PM
MkC2S's Avatar
I noticed that on my mine awhile back...oil dripping from the driver side near the exhaust....it could be your sparkplug tubes & Orings gone bad....G/L & hopes its nothing serious..
Old Dec 11, 2011 | 03:24 PM
Frankb914's Avatar
Thanks for the reply
Is there any way I check to see if those items are the problem, or do I need to see a mechanic
Old Dec 11, 2011 | 04:00 PM
logray's Avatar
logray is infamous around these partslogray is infamous around these parts
Clean the area where the leak is coming from and see if it returns.
Old Dec 11, 2011 | 11:42 PM
Peterpokerplane's Avatar
Peterpokerplane is infamous around these parts
I vote spark plug tube o-rings. Very easy and relatively cheap to change out if you can remove the mufflers. The only special tool you need to a transom plug (cost less than $5) and a couple hours and you should have your problem solved.
Old Dec 12, 2011 | 05:39 AM
Frankb914's Avatar
Sparkplug rings seems to be the concensus, I will go there. TKS
Old Apr 9, 2012 | 12:14 AM
jayi836's Avatar
jayi836 is infamous around these partsjayi836 is infamous around these parts
Frank what did you find I have a similar issue with my 99 C2
COBB Tuning
Jan 1, 2025 09:02 AM
2lflat4
Nov 18, 2019 05:05 PM
joseph_number1
Jul 19, 2018 05:45 PM
Senatorblutarsky
Aug 28, 2015 12:44 PM
Phoenix604
Aug 19, 2015 10:39 PM
