FRONT PASSENGER Airbag removal help
I have not done this on a Porsche but on other cars: disconnect battery cables & touch together to disapate static, then wait 5 minutes before touching airbag. Passenger cover is not removeable it has a thin seam that will breakaway if airbag deploys. Airbag access is thru glove box or from under dash.
I've removed the dash a couple of times on the 996 (and getting ready to do it again soon). Where are you stuck? There are 2 bolts that hold the airbag unit. You get to them from underneath the passenger side glove box area.
Enemy
Nov 10, 2015 08:01 AM
pwdrhound
Aug 23, 2015 07:36 PM
riozilla
Aug 21, 2015 11:34 PM
