Oil capacity
It seems like everyone is having a problem with drainage time. It is no surprize to me considering the flat design of the pan. There is no place for the oil to accumulate, so it's draining from a flat plate. My concern about this design is that unless this flat plate is exactlly parallel with flat ground, you may get a significant amount of oil pooling at the low end. The more of an angle the car is, the more oil that will not drain out. What concerns me most is if you drain the oil in the same unlevel stop everytime, although you are diluting your old oil at some rate, any metal or sludge may be settling and accumulating in that low spot.
Is there any guidance as to how oftern this pan should be dropped for a thorough cleaning?
Correction on earlier post, LNE sells a deep sump kit which adds a spacer between the engine case and sump plate. They do not sell a new sump plate. Their spacer adds capacity to the oil system.
Also it hasn't been mentioned yet, but drain your oil when the engine is warm, you'll get more bang for your buck on drain time and oil drained vs. a cold engine.
I'm interested in the answer on how often to drop the pan too. I know LN Engineering makes a slightly deeper pan, but it is still flat too to my knowledge. Just to be OCD, on my oil change I put the old plug barely in, heated up a quart of Mobil syn that was 3/4 full and poured it through. I then undid the plug and it came out pretty darn quick and looked as clean as it went in. I did not expect to get sludge, but was at least hoping for washing some additional particles out....which may have happened...who knows. I left my car on jack stands and the angle was pretty forward. Looking back at it, I guess I should have lowered it and let it drip too. Does anyone do this?
I've drained the oil in my Porches more than once and while I have the engine hot the cars are on ramps. I drain the oil for as long as the oil runs more than a thin stream. I do not have the patience to wait until the stuff stops running out entirely.
There's no need to remove the pan. It is a waste of time. Besides if the pan is oil tight now it may not be oil tight afterwards. IOWs, if it ain't broke don't fix it.
There's no need to flush the engine. There will not be enough flow velocity to remove any particles at the bottom of the oil pan. Besides if they're light enough to be flushed out the drain hole they will have been inhaled/ingested by the oil pump and pulverized by the oil pump and the fragments in the oil filter housing or in the oil filter element.
Early on I checked to see if there was any benefit to having my car level and I found there wasn't any, at least within reasonable amounts of tilt. like the rear of the car raised from backing the car up on a pair of Rhino Ramps.
The engine is designed to encourage any oil that can drain back into the sump to drain into the sump when the engine is off and the car is sitting at almost any angle.
If the oil didn't do this it would collect and the engine would starve for oil even climbing or descending a grade.
In short, get the engine up to temp.
Back the car up on ramps or use a lift to lift the car up so you can get under/work on the car safely.
Remove the drain plug -- careful the oil is hot! -- and let the oil drain 20 minutes. Remove and replace the filter. Use a new filter housing o-ring.
Reinstall the drain plug using a new seal washer. Be sure you use a good torque wrench to properly secure the drain plug and oil filter housing.
Dump into the engine the appropriate amount of oil. This varies from model to model and can vary from car to car as Porsche might have made an internal engine change during a model run that resulted in a slight change in the engine's oil capacity.
The techs get updates/bulletins to the factory manuals that let them know what the right amount of oil is.
You can ask and probably a tech will tell you. Or the parts department might tell you if you supply a VIN.
Add this amount of oil to the engine. Double check you added the right amount of oil. Count the empty bottles twice.
Before you start the engine double check under the car you didn't leave a drain plug out of the hole.
After starting the engine and driving the car off the ramps turn off the engine and let it sit while you put things away.
After a while check the oil level. It should be ok. If not the oil level sensor/sender is defective. It is by putting in the correct amount of oil that allows one, gives one the chance to verify the oil level sensor/sender is working properly.
Sincerely,
Macster.
In addition to the above excellent advice on the initial fill after drain I would recommending adding slightly less than what is called for (perhaps .5 to .25 fewer quarts), running the engine for about 30 seconds or so, shutting it off, waiting another interval of time (perhaps 10-15 minutes) and then adding the remaining amount to get to the acceptable level.
albert@velosdesignwerks
American Muscle Vendor Classifieds
Sep 9, 2015 04:21 PM
Other British Cars
Sep 9, 2015 04:18 PM
Sep 9, 2015 04:17 PM
GT3/GT2/GT Vendor Classifieds
Sep 9, 2015 03:55 PM
997 Vendor Classifieds
Sep 9, 2015 03:51 PM
