Question on parts required when doing plugs
Old Feb 26, 2012 | 05:11 PM
flybye_'s Avatar
flybye_ is infamous around these parts
So I’m going to attempt changing the plugs since the dealer wants $700 including parts.
My question is what else should I change while I’m in there? She’s a 2004 with 15k, it’s only because of time, and the book states the plugs should be done.
Old Feb 26, 2012 | 05:38 PM
logray's Avatar
logray is infamous around these partslogray is infamous around these parts
I would just do the plugs. Go with OEM plugs only.
Remove the mufflers and it's a lot simpler.
Old Feb 26, 2012 | 10:06 PM
RobbC's Avatar
RobbC is infamous around these partsRobbC is infamous around these parts
I did spark plugs and tubes but I have 98K miles... Two of the banks from each side were leaking on mine.
You'll need this: https://www.6speedonline.com/forums/...e-removal.html
I ordered my spark plug tubes from pelican and the plug remover off amazon.
Old Feb 26, 2012 | 10:15 PM
bensonJ's Avatar
bensonJ is infamous around these parts
Your 04 doesn't have spark plug tubes so that is no worry. Just inspect the coils while you have them out. Check for split plastic or rust poking out near the top and replace any bad ones.
COBB Tuning
Jan 1, 2025 09:02 AM
Sep 1, 2015 03:16 PM
Aug 21, 2015 06:34 AM
Aug 19, 2015 06:55 PM
Nissan GTR
Aug 19, 2015 02:11 PM
