Hollow wheel part # help
Old Apr 4, 2012 | 08:38 PM
theoilman's Avatar
theoilman is infamous around these parts
Hey guys,
I took my wheels off and was wondering what size my rear wheels are. The front were straight forward, 7.5 width (993.362.134.05).
The rears not so much as both part numbers are stamped on the back of my rear wheels:
9in width part # (993.362.138.00 "B")
10in width part # (993.362.140.00 "A")
Both offsets are stamped too:
9in offset and width- (9Jx18-ET52 "B")
10in offset and width- (10Jx18-ET65 "A").
Can anyone point me in the right direction?
Old Apr 4, 2012 | 09:37 PM
rrrruben's Avatar
rrrruben is infamous around these parts
My 99 996 C2 was originally sold with a PLUS 1 wheel combo:
OEM WHEEL COMBO:
205/50/17x7 F 25.07 diameter; 50ET
255/40/17x9 R 25.03 diameter; 55ET
PLUS 1:
225/40/18x7.5 F 25.08 diameter; 50ET
265/35/18x10 R 25.30 diameter; 65ET
Are your rear tires: 265/35/18 ? If so, 65ET should be correct.
Old Apr 4, 2012 | 09:46 PM
theoilman's Avatar
OEM WHEEL COMBO:
PLUS 1:
Yes, 265/35's in the rear! So, after 2 hours of searching I was about to post since I found an answer a little different to yours too and both make sense. If you look a little closer by the hub, you'll notice two boxes marked "A" and and "B". The box will be marked with an "X" with what wheel width/offset you have, my box was checked off on the letter "A" so the wheels definitely are the ET 65's you speak of:
The manufacturing process (whatever that was, as I wasn't there at the time) would be the same either way - but from the 996/986 era, for obvious manufacturing reasons, the central section was made for two width rims, so both these part numbers were 'cast' into the central section.
How do I know?
1) I read it somewhere
2) why else would you have two part numbers, with an A and B and ticked boxes on any object, unless some part of it was shared.
3) An alloy wheel came to me in a vision, and sayeth it was so.
Old Apr 4, 2012 | 10:03 PM
rrrruben's Avatar
Being that I was not the original owner of my 99 P-car, I have never seen the original PLUS 1 rear wheel. However, in the course of my research, an alloy wheel came to me in a vision, and sayeth it was so as well.
Old May 24, 2019 | 11:17 AM
WaddyP's Avatar
WaddyP is infamous around these parts
Why does it say 17 for the fronts if they are 18" tires?
Old May 24, 2019 | 11:35 AM
ZuffenZeus's Avatar
ZuffenZeus is infamous around these parts
What are you referencing?
The 996 will accept both 17" and 18" wheels/tires as long as they are within OEM specs.
Old May 24, 2019 | 01:34 PM
WaddyP's Avatar
PenguiN
Oct 26, 2018 07:23 AM
COBB Tuning
Nov 9, 2015 08:02 PM
007 Vantage
Sep 4, 2015 06:55 PM
ppwchiang
Aug 20, 2015 10:28 AM
