Leak in A/C system?
Old May 27, 2012 | 09:37 PM
speedyvespa's Avatar
speedyvespa is infamous around these partsspeedyvespa is infamous around these parts
Leak in A/C system?
I took my new (well, new to me - 2001 TT with 19300 miles on it) to the local Porsche dealer to get a key programmed and had a point to point inspection while it was there... kind of a little nerve wracking. Anyway, the good news is that she has a clean bill of health, appears to be an A1 car. Whoot!
The only question was about the A/C levels... fluid appears to be a little low and they're wondering if there's a leak. They say they can top it off if I have it serviced with them and they'll put dye in it or something, but I'm wondering if this is something I can do myself? Anyone know?
They also recommended a complete brake fluid flush because we don't know when it was done last (apparently should be done every two years) - same thing with the spark plugs. Seems reasonable to me, then I know the car's history from this point on... is that a sound philosophy?
TIA!
Old May 27, 2012 | 10:01 PM
djantlive's Avatar
plugs dont need to be done at such low mileage for sure
brake fluid is required every 2 years. if you know where the car was located, maybe the service history can be obtained if you call the local porsche dealer. this is often overlooked service so doing it would be a good idea.
as for the AC, you can have an AC shop use a sniffer to detect where the leak is. this takes about 20 mins. if the ac is still cold, the leak if any may be really insignificant. i'd go to an ac shop and they'll probably do it for free.
Old May 28, 2012 | 07:17 AM
Thanks! I appreciate the reply.
Out of interest, how often should the spark plugs be replaced?
Old May 28, 2012 | 09:58 AM
Fozzybear's Avatar
Fozzybear is a glorious beacon of lightFozzybear is a glorious beacon of lightFozzybear is a glorious beacon of lightFozzybear is a glorious beacon of lightFozzybear is a glorious beacon of light
It varies somewhat model to model and year to year. For the 01 TT the major maintenance schedule is every 30K miles.
Old May 28, 2012 | 10:15 AM
djantlive's Avatar
check your manual, the service interval is in there. it's definitely not 20k miles and changing it earlier doesn't get you any more power or fuel economy.
Old May 29, 2012 | 12:29 AM
Omarcoolguy's Avatar
Omarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant future
Nothing wrong with changing your plugs , DIY ..
As far as the AC I would have the system recgarged , but don't just fill it with freon , have them hook it up it will vacuum out the whole system and check for leaks , and fill it back up ...should be good to go then
RallyBird
Oct 7, 2015 01:20 PM
LiquidElephant
Aug 27, 2015 06:17 PM
PelicanParts.com
BMW Vendor Classifieds
Aug 25, 2015 03:55 PM
Because_R4CEC4R
Aug 23, 2015 08:53 PM
