water in oil cap and overheating
Old May 28, 2012 | 07:57 AM
bilba's Avatar
bilba is infamous around these parts
I saw water in the oil cap every day
Temperature rises up to 97c when driving a long trip like 30 mins
Cleaned the radiator and chanhed oil separator
There is no oil sign in the cooling system or oil gauge
I live in a warm area
What is the cause of abnormal high temperature and What is the reason of water in the oil cap every day?
carrera2 99
Old May 28, 2012 | 08:39 AM
Parkcity911's Avatar
Parkcity911 is infamous around these parts
What oil are you using? Do you normally drive longer drives or shorter. I've heard on these forums some that us Mobil 1 0-40 have had issues with creamy whitish oil in their filler tube. Glad you changed it / send in a sample for analysis to see if you have a coolant leak into your oil.
Also, take off the front bumper and completely clean and take the A/C condensor off the radiator and clean those both. You will need a brush to work in between the fins to ensure you get it all cleaned out. Has your coolant been done lately? At minimum have it tested. I would also add water wetter by Redline to help keep it a bit cooler. If the temps keep up and you're consistently in or near the red zone....I would also suggest the lower temp T stat you can get at Pelican or LN Engineering. It is fully open at 185 vs 210 to keep you a bit cooler from the get go. I still get hot, but it seems to stay cooler longer and also recover faster when cruising or going down a hill after a hard run up a longer hill.
Just ideas: keep us all posted on the water. Seems you are getting it hot enough to burn off condensation, so I don't know what to tell you other than have it analyzed by Blackstone. You can pull a sample through the filler tube to send in. Good Luck!!!
XLR82XS
Oct 5, 2015 07:02 AM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
m_motorsport
Sep 2, 2015 12:53 PM
