rear rigth running lights
Old Jun 25, 2012 | 11:53 AM
hramos's Avatar
hramos is infamous around these parts
If someone can help thank you
I have a 99 911 cab. Right rear running lights dont work but brake lights do. I changed the harness and still not working Tested the tail light assembly on passenger side and it works any idea??
Old Jun 25, 2012 | 12:32 PM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Not sure if this will help. I would check to make sure there is no corrosion on the bulb and in the socket, then use a volt meter to ensure you have current going into the socket. Could be a bad fitting bulb or something preventing the electric from getting to the fixture.
Old Jun 26, 2012 | 10:14 AM
Slider's Avatar
If you have already tried to track down the open wire and are at a loss, you can always run another running light wire from the left side.
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
COBB Tuning
Nov 9, 2015 08:02 PM
TrackOne
Aug 20, 2015 12:56 PM
Walorus
Aug 18, 2015 01:39 PM
