Oil pressure indicator issue...WTF is going on
Old Dec 19, 2012 | 02:43 PM
rrrruben's Avatar
rrrruben is infamous around these parts
I realize that once you fill up, and turn the key to the first position, one gets a read of the oil level status. However, the last two times I filled up, the oil level indicator read very low as well as the oil pressure indicator (below 2). Once I get going, both indicators are back to normal. I am guessing an electrical glitch, or something is on it's way out. Any thoughts, or similar experiences, would be greatly appreciated.
Old Dec 19, 2012 | 02:45 PM
Dennis C's Avatar
Have you checked the oil on the dipstick? That's where I'd start.
Oil sending units sometimes fail on these cars, causing dropouts on the oil pressure gauge.
Old Dec 19, 2012 | 06:34 PM
invius's Avatar
invius is infamous around these parts
+1 on oil sender unit, will cause these types of glitches.
Cheers,
DS
Old Dec 20, 2012 | 06:09 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Yup, sender
Old Dec 20, 2012 | 07:28 AM
Macster's Avatar
Oil level is dependent upon temperature. A cold engine's oil level will read lower than the same engine parked in the same spot and fully warmed up.
Since it has been cold (for this area) the last couple of days you may be experiencing this for the first time, or having experienced it last year and having forgotten about it.
I have to ask: The oil is relatively fresh and something approved?
Old Dec 20, 2012 | 10:59 AM
rrrruben's Avatar
Originally Posted by Macster
...I have to ask: The oil is relatively fresh and something approved?
Mobil 1 0W40 3,000 miles ago. Checked the dipstick, and I was about 3/4 of a quart low (Thank you Dennis C). I added 3/4 quart of fresh oil, and hopefully, issue solved. If not, looks like a new oil sender unit. Thanks all.
ant_8u
Apr 10, 2016 11:42 AM
as4driver
Sep 10, 2015 09:32 AM
ECS Tuning - VW
Sep 8, 2015 01:34 PM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
