Engine code question
Old Feb 15, 2013 | 02:57 PM
Silent One's Avatar
Silent One is infamous around these parts
I have an 03' C4S the check engine light has come on . I had O'Rileys check it and the code is P0507, they did not know exactly what it ment except high engine idle. Car is located in SLC UTAH, and stored winters. Can anyone help me with this problem or suggest a reliable shop? Thanks
Old Feb 15, 2013 | 07:25 PM
Jpelton's Avatar
Jpelton is infamous around these parts
First thing I would check for is vacuum leaks, or tears in the bellows/leaking near the hose clamps going between your throttle body and intake manifold. This could cause unmetered air to enter your system, which can cause the symptom your describing as more air is entering the motor than what the ECU is seeing by the MAF reading.
Could also be a damaged or gunked up throttle body, never a bad idea to pull and clean that.
Also believe the PCV system could be the cause of that, I would check the function of your AOS to see if it is functioning properly.
Unfortunately that code can be caused by many things, it is not as cut and dry as some codes. May take some digging around and testing various components before you are able to track it down. Start with checking for vacuum leaks, those always cause issues.
-John
Old Feb 16, 2013 | 08:56 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
P0507 Idle air control at stop - above limit
Possible fault cause
Oil filler cap not on tight, this will cause a vacume issue and trigger the CEL code
- Throttle is jammed
- Leaks in intake air system
Jul 29, 2019 11:13 AM
turbotuner20v
Sep 11, 2015 12:02 PM
oddjob142
Aug 24, 2015 05:49 PM
Aug 19, 2015 06:55 PM
