CDR23 Bose system OEM radio
Old Mar 26, 2013 | 10:50 PM
911C4S's Avatar
911C4S has a spectacular aura about911C4S has a spectacular aura about911C4S has a spectacular aura about
Help! Is there anyway I can hook up my iphone to the CDR23 radio in the least expensive way? I only have the radio hooked up and not a cd changer. Thanks guys!
Old Mar 28, 2013 | 12:20 PM
nymart's Avatar
nymart is infamous around these parts
Least expensive way I know is to pull your radio and send it to Becker Autosound in New Jersey. For $100 they will hard wire an aux into your radio.
Old Mar 28, 2013 | 04:57 PM
Kjc227's Avatar
Kjc227 is a jewel in the roughKjc227 is a jewel in the roughKjc227 is a jewel in the roughKjc227 is a jewel in the rough
I'm sending mine in on Monday to Becker.
Old Mar 28, 2013 | 08:19 PM
Slopeslider2's Avatar
Slopeslider2 has a spectacular aura aboutSlopeslider2 has a spectacular aura aboutSlopeslider2 has a spectacular aura about
Sosche Ipfmrds found at Crutchfield. Does a great job. Checkout this thread https://www.6speedonline.com/forums/...96-mkii-3.html
Old Mar 30, 2013 | 07:55 AM
Sharp's Avatar
Sharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud of
here: http://www.iwirep.com/products/iwirep-220-ipod
plugs in instead of the CD changer...
Old Mar 30, 2013 | 11:17 AM
pfbz's Avatar
pfbz is a jewel in the roughpfbz is a jewel in the roughpfbz is a jewel in the rough
I know these work with the earlier CDR-220 head units, do they also work with the CDR-23? My understanding is that they did not..
Q.) What won’t the iWireP-220 work with?
A.) The iWireP-220 connects to the CR/CDR-220 head units through the C3 AUX port. Other factory head units may also appear to have this port, but they are not properly wired to support our cable. DO NOT ATTEMPT TO USE OUR PRODUCT WITH A DIFFERENT FACTORY HEAD UNIT!
Old Mar 30, 2013 | 11:31 AM
Sharp's Avatar
Hmm, was not aware of the diff, thought they had a few different models... My bad thought it would be a cheap and quick solution for ya
Old Mar 31, 2013 | 06:03 AM
xxaarraa's Avatar
xxaarraa is infamous around these parts
Kind of a related question - anyone know of the cheapest way to add bluetooth connectivity to the factory radio? Doesn't have to be A2DP, just phone would be good enough.
Old Mar 31, 2013 | 08:32 AM
aedolfan's Avatar
aedolfan is infamous around these parts
Check out Pioneer's "app radio". Got mine for $299. Connects directly to the speaker connecters without clipping wires. Which means you use the Bose amp. Find the power wires and ground (I.D.'d on the stock head unit) as well as the steering wheel controls, if you have them, a slight modification radio housing and bezels. Done. You get bluetooth connectivity, Sirius radio, talking maps, contacts etc etc. You get all the things your mobile phone has on a nice 7" screen. Mine works flawlessly...
Old Apr 1, 2013 | 04:27 AM
Kjc227's Avatar
Do you have the link for the pioneer model?
Thanks in advance.
Old Apr 1, 2013 | 09:56 AM
aedolfan's Avatar
pioneer.com
under the tab appradio
Old Apr 1, 2013 | 03:34 PM
Kjc227's Avatar
pioneer.com
Doh? Thanks I'll take a look.
Old Apr 6, 2013 | 01:40 AM
judgejon's Avatar
judgejon has a spectacular aura aboutjudgejon has a spectacular aura about
yes, thats about the only thing that will really work. you can then put a jack at the back of the little ditty box on the console. check for a diy on renntech.
Old Apr 8, 2013 | 09:52 AM
911C4S's Avatar
Is there a shop in SO.Cal that can perform the same installation as Becker in NJ? I would think so. Thanks
Old Apr 9, 2013 | 06:10 PM
Kjc227's Avatar
Waiting on Becker to ship it out.
Will update as I receive it.
