ABS and PSM light
Old May 6, 2013 | 06:14 AM
bmtbandit's Avatar
bmtbandit is infamous around these parts
ABS and PSM light
I am getting an occasional ABS/PSM light combo. It seems to happen with hard acceleration and has only happened 3 times over several trips. A power cycle of the car seems to reset the issue.
Does this sound like the typical scenario caused by the MAF sensor? I know I read several threads on this issue, but can not seem to find them at the moment.
Also are there codes that the Torque APP would be able to read to help diagnose this issue?
Old May 6, 2013 | 06:58 AM
jumper5836's Avatar
jumper5836 has a spectacular aura aboutjumper5836 has a spectacular aura about
Could be the brake switch.
Old May 6, 2013 | 07:00 AM
bmtbandit's Avatar
Would the brake switch cause it if it happens before hitting the brake?
Old May 6, 2013 | 08:41 AM
jumper5836's Avatar
I'd think not. Is it stock filter and intake? I'd replace filter and clean MAF. Reset the code and see if it comes back.
Old May 6, 2013 | 09:21 AM
bmtbandit's Avatar
Yes stock, I will give it a shot and see. Thanks.
carwash
Sep 26, 2015 03:11 PM
henryr
Sep 24, 2015 08:22 PM
Airbus Driver
Cayenne 958
Sep 2, 2015 12:50 AM
hacellular
Aug 31, 2015 08:34 AM
GSR Autosport
Aug 26, 2015 05:20 PM
