Stock C2 Suspension Rear Too Low?
Old Jul 25, 2013 | 11:13 PM
carrera4slakem's Avatar
carrera4slakem is infamous around these parts
Guys, front has 1.25 inches taller wheel gap then the rear which sits at .75 inches of wheel gap.
Is there anything I can do to modify the rear to make the wheel gap taller to match the fronts? Would putting some new shocks help or new both shocks and springs.
I can't stand the dead body in the rear look. Any suggestions while keeping the factory suspension setup? It's crisp and tight enough already for my old body.
Old Jul 26, 2013 | 04:33 PM
alpine003's Avatar
Put a dead body in the frunk. Problem solved.
Old Jul 26, 2013 | 04:43 PM
lol, I'm going to do the muffler bypass and see if the 60lbs diet on the rear relieves and of the drag down.
Old Jul 26, 2013 | 04:51 PM
alpine003's Avatar
Muffler bypass will only net you closer to 50lbs and won't do a thing to ride height.
You're gonna have to get springs at the very least if you want to do it right.
You can maybe stack spring pads out back but I would not recommend this as there will be labor and alignment involved.
Old Jul 26, 2013 | 06:20 PM
pfbz's Avatar
pfbz is a jewel in the roughpfbz is a jewel in the roughpfbz is a jewel in the rough
Something doesn't sound quite right... My 2004 C2 had pretty similar gaps with the stock suspension.
Is it possible you have an incorrect size front or rear tires on the car which are affecting the gap? Possible that somebody previously swapped front or rear springs? Are there a ton of miles on the car?
Shocks will have no effect on ride height, unless they have adjustable spring perches, and OEM C2 shocks do not. I suppose it is possible that rear springs have fatigued and that is what is causing your rear to droop, but it seems a bit unlikely...
If you do replace springs, I would definitely do all four. Tons of people have dumped there stock springs for either coil-overs or H&R replacement springs, so it shouldn't be too hard to source a set of low mileage used springs.
You can also take a look at my H&R Install thread for some before/after pictures on my C2 for comparison to how your car is sitting.
Old Jul 27, 2013 | 10:48 AM
fast996's Avatar
fast996 is infamous around these parts
lol - the old Chicago dead body in the frunk technique
OP, you have any pictures of how the car sits? maybe time to replace tired springs. Good excuse for some upgrades I say-
COBB Tuning
Jan 1, 2025 09:02 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
gulf gt
Aug 27, 2015 10:27 AM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
