plz help battery dead... hood and rear lid locked
I've searched every forum. Everyone has a different answer…
some people say the car is in sleep mode… my remote won't unlock the doors. i currently have a trickle charger connected though the fuse box (fuse #c3) but all it does is display the airbag sign in the dash… where are the emergency release cables located?! PITA Thanks Eric |
you dont need emergency release cables.
open up your fuse box (under drivers side) and you'll see a big shiny gold/copper contact for you to clamp a battery booster cable up to (will have a symbol on it that looks like the hood/frunk opening). Positive side goes there, negative side goes to anywhere on the car that you can ground it (screw, frame or in my case, i used the metal door latch). This will provide power to the frunk release. Bam. front opens and you got access to the battery. |
i wish i had that positive tab pull out in my fuse box. but my 99 doesn't have that unfortunately, thats why i had to plug into fuse c3
no luck so far, pretty cold out trying to figure this out wheres the easy button :o |
Go to an auto store and get a battery charger that plugs into the cigarette lighter. Had that happen to me a few times.
99 has a manual front hood I thought. Shouldn't need power
Originally Posted by djantlive
(Post 4045483)
(Post 4045483)
Pull the manual release for the engine compartment and you may find a positive connection for a jumper cable under a pop-open black cover in the engine compartment. Best of luck. --Woody |
Try to find a cable that is located under the right headlight, for this emergencys. You need to insert a smal hook to find it, the same cable is also under the rear letf light. When you find it , pull to open the hood or trunk, good luck.
Alright I'll try fishing for these cables tomorrow...
Thanks guys |
OK GUYS ! For all of you with a pre 2001 996/986 with the mechanical hood release latches that are locked by the electronic solenoid. I've Figured out how to open the hood, stress free! (for you)
If your battery is too dead it may not be able to take a charge from a battery maintainer/charger even after days of charging so forget the cigarette lighter or the fuse #c3 trick forget looking for the emergency release cables What you need to do is: *locate the 3 small holes on the plastic trim that surrounds the latches *take a 5mm allen key and loosen the bolts inside ONLY 1 TURN OUT *Lift up the assembly and locate the plate that stops the latches from being pulled *Slide that plate toward the passenger side of the car and VOILA ! You are free to open the hood and engine cover as you please, unlock the driver door via the key hole to silence the alarm Pics to come my only problem now is the car wont start. could be the ignition switch or key :s |
Originally Posted by peterson911
(Post 4047714)
If your battery is too dead it may not be able to take a charge from a battery maintainer/charger even after days of charging so forget the cigarette lighter or the fuse #c3 trick forget looking for the emergency release cables What you need to do is: *locate the 3 small holes on the plastic trim that surrounds the latches *take a 5mm allen key and loosen the bolts inside ONLY 1 TURN OUT *Lift up the assembly and locate the plate that stops the latches from being pulled *Slide that plate toward the passenger side of the car and VOILA ! You are free to open the hood and engine cover as you please, unlock the driver door via the key hole to silence the alarm Pics to come my only problem now is the car wont start. could be the ignition switch or key :s --Woody |
I guess they allowed the rear engine cover to open after the 1999 MY cars !
both my hood and rear engine cover were locked out completely! cheers |
