Wheel offset gurus, NB help
Old Feb 25, 2014 | 11:00 PM
adrce55's Avatar
adrce55 is infamous around these parts
Hi everyone,
I have a 1999 C2 996...
I found some rims with the following setup:
19x8.5 ET 40 front
19x10 ET 62 rear
I used the calculator on 1010tires.com and it looks like it should be ok, but I wanted to be sure before I invest my money into these wheels.
Can anyone help/confirm?
Thanks in advance...
Old Feb 26, 2014 | 06:42 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Look on the rim, it will be stamped on one of the spokes I believe. It will look lik this: 8Jx18HZ ET57 the first number is the rim width in inches, the J is the rim flange contour color letter, the x is the symbol for drop center rim, the 18 is rim diameter in inches, the HZ is double hump, and the ET57 is the offset in MM.
Old Feb 26, 2014 | 07:44 AM
Sleek996's Avatar
Sleek996 is infamous around these parts
At the offset listed, you shouldn't have any problems. Post some pictures of the wheels, I'm sure someone will chime in and positively verify it for you.
Old Feb 26, 2014 | 08:36 AM
NineEreven's Avatar
NineEreven is a jewel in the roughNineEreven is a jewel in the roughNineEreven is a jewel in the rough
yea that will work. Doesn't leave to much space full lock in front without touching the wheel well and the tires have a lot to do with it.
Old Feb 26, 2014 | 10:15 AM
Pors-Vette's Avatar
Pors-Vette is a jewel in the roughPors-Vette is a jewel in the roughPors-Vette is a jewel in the rough
I agree with NineEreven. The rears will fit fine with the ET but the fronts may rub the wheel well depending on tire size.
Old Mar 2, 2014 | 11:01 AM
adrce55's Avatar
I was seeing the same thing, as far of fitment on the front, from the calculator on 1010tires as well but all your inputs confirmed. Thanks!
The wheels I was interested were some 19in 3pc Cargraphics listed on SF Craigslist. Have a look, maybe someone else wants them...
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
