1999 996 transmission problems
Hi all, I'm new here. I'm interested in a 99 model 996 that has a transmission issue. It pops out of first gear sometimes and sounds/feels like a crunch or grinding noise from third gear into fourth. Wondering if anyone has had similar issues? I'm new to Porsche but have always wanted to own one. Your input is greatly appreciated, thanks. It's a c4
I'll take a stab; it could be the shaft bearings causing the pop out, incorrect gear oil (to light needs 75w). There have been many who experienced 2nd gear pop out and installed the GBOX Detent, I know of one person who experienced 1st gear pop out and installed it and the problem went away.
http://www.gboxweb.com/detent.html
But to the latter problem with grinding sounds like the clutch is not full engaging, but start with the Detent first, minor inexpensive fix first, let's try least expensive first.
I wait with baited breath
b-man
I recently had the same issue issue with 1st gear but no others were problematic. Contact Frank at porschewrench@gmail.com and he may be able to sort you out as well.
You can get it directly from Ebay at 199.00
http://www.ebay.com/itm/PORSCHE-TRAN...21d6fe&vxp=mtr
tropicatango
Jun 8, 2025 01:00 PM
2lflat4
Nov 18, 2019 05:05 PM
pshep138
Sep 1, 2015 09:45 AM
LiquidElephant
Aug 27, 2015 06:17 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
