Hi Guys, Need help with removing Front Bumper
Old Nov 25, 2003 | 09:51 AM
Shawn C's Avatar
Shawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond repute
I am having it re-painted along with the Bumperettes and Center Console. The only part I dont know how to remove is the front bumper. Thanks in advance
Old Nov 25, 2003 | 10:07 AM
Erik@Cargraphic's Avatar
Erik@Cargraphic is infamous around these parts
Jeru
The removal of front bumper is pretty straight forward.
Under the bumper remove the six torx screws (T25)
pop out the side marker lights.
in each side marker opening there are two phillips screws. in order to remove one of the two you have to pull the spalsh gaurd out of the way. this is done by removing the 3 clips facing froward on each side.
Next remove blach plastic cover under the hood where it meets the bumper. this is done by turning the 4 plastic clips 1/2 turn.
Finally under that cover is two phillips screws.
the bumper should slide right off.
good luck
Erik
COBB Tuning
Jan 1, 2025 09:02 AM
brockster
Jan 22, 2016 12:18 AM
TrackOne
Aug 20, 2015 12:56 PM
Nissan GTR
Aug 19, 2015 02:11 PM
m_motorsport
Aug 19, 2015 03:34 AM
