Help with K&N cold air intake
Old May 13, 2017 | 08:29 AM
Jeremyh's Avatar
Jeremyh is infamous around these parts
My 996 came with the k&n already installed. I removed it recently while doing my water pump. When reinstalling, i found the rubber well nuts that the bottom bolts to were rotted to death. Are these well nuts from the k&n kit? Or were rhey a factory part? Trying to find replacements?
Its the rubber well nuts that the bolts in the pic would screw into.
Old May 13, 2017 | 10:08 AM
bushrat's Avatar
bushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond repute
Just replaced a few of these rubber nuts. They are used in the frunk to anchor the factory cd stacker as well as the panels on either side of the battery. Dealer should be able to order these for you.
Old May 13, 2017 | 04:30 PM
wildbilly32's Avatar
wildbilly32 is infamous around these parts
Jeremy: If bushrat is correct this is the "rubber nut" that holds the side panels in the frunk in place. I cannot verify this is what you need.
part #99950009200
Number 13 in diagram. $4.41 from Auto Atlanta
http://beffc355b172a4d82d12-6d84f9e6...com/813-20.gif
Old May 14, 2017 | 09:16 AM
Jeremyh's Avatar
Not sure if they are the same size. These are pretty big, looks,like 1/4" size bolt
Old May 14, 2017 | 10:32 AM
bushrat's Avatar
Try this part# 99950007800 1/2" body,6mm thread (apx 1/4")
