Issues going into 2nd gear... help?
All, I have a new to me (2nd owner) '02 C2 Cab. It has a weird issue of not wanting to go into 2nd (sometimes) when going up or down hills. Last night I was going down a short hill after turning at a stop sign and I put the clutch in and moved to 2nd and I heard a lot of grinding when I partially let the clutch out. I didn't let it all the way out, just put it in neutral and coasted. When I got to the next stop sign, I ran through first and second with no problem but this was on less inclined terrain. Another time, I went to 2nd and it felt like I was in neutral, like it didn't "hook up". I am aware of the "second gear popout" issue and this seems to be more of a question of the car not going into 2nd as opposed to coming out randomly once engaged. Anyone have any insights?
My '02 Cab would do the same thing on occasion, replaced the stock shifter with a 997 short shifter and problem went away.
Is it only at certain RPM's? Could be an issue with the synchro's.
I'm not sure, it's basically on upshift from 1st to 2nd. Not high RPM shifting at all, very low speed/load. But only on a hill. Does upgrading to the short shift kit also involve transmission fluid flush and fill? I'm thinking that might be the first thing to try.
Originally Posted by antagron
(Post 4639659)
I have experienced clutch and shifting problems from letting my 2002 Boxster go just 2.5 years between brake and clutch fluid flush/bleed jobs. While the brakes were ok before and after the fluid flush/bleed the clutch and shifting action while a problem before the fluid flush/bleed were transformed afterwards. |
I am not sure if this related to your issue, but you should check this out https://www.6speedonline.com/forums/...dance-mod.html
And their website. http://www.gboxweb.com/detent.html |
I talked to my mechanic, who said it's the synchro wearing down and to just avoid the problem by learning what RPMs the car wants to shift at. Shifting at over 3k, I haven't experienced the problem. I guess I just need to learn the car more...
Well, I'Ve had a similar problem in the past, and I try to let the engine warm up for about 10 minutes before start driving and that loosen up the gear box, some people might think is not good to do that and that should start driving the car slowly, but I don't agree. Glad you figured it out.
Originally Posted by Rental Metard
(Post 4639774)
