Help with a noise
Old Aug 7, 2017 | 02:29 PM
RobbC's Avatar
RobbC is infamous around these partsRobbC is infamous around these parts
Exclamation Help with a noise
Hi all,
It's been a while.
I'm trying to figure out what this noise is before taking into the shop. Please let me know what you think it may be. IMS/RMS replaced at 96K miles. Currently at 106K.
Thanks in advance.
Old Aug 9, 2017 | 07:53 PM
Macster's Avatar
If you only hear the noise when the transmission is engaged and the engine is supplying torque to the transmission/diff very likely it is transmission/diff related.
Long shot but I assume the tire treads do not manifest any signs of severe misalignment? No feathering/cupping of the tread blocks?
Since you are taking it to the shop is it necessary to know before hand what the source of the noise is? Your job is to tell the tech how to reproduce the noise so during a road test he can produce the noise and make his diagnosis.
As a general rule, when the car (engine, drivetrain) is making noise the less engine run time, the less use the car receives the better. The goal is to with as little engine run time, road test time, as possible make the diagnosis and then proceed to fixing what's wrong.
