Help buying 996 2001 C2 or C4
Old Mar 1, 2006 | 02:44 PM
CLS's Avatar
CLS
CLS is infamous around these partsCLS is infamous around these parts
I am currently not a Porsche owner put hope to be one very soon! What I am looking at dollar wise is biggest bang for my buck is the 2001 series 996, either a C2 or C4. There seems to be more C2's to choose from and less money than the C4's. The other question is the coupe verses the cab, performance, weight, safety? I most likely will want to add some handling features to the car, some minor performance bolt on products. So which is car provides the best base to work from? Thank you in advance for your help!
Old Mar 1, 2006 | 04:24 PM
WyattH's Avatar
WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !
I imagine the coupe is lighter, stiffer, and safer than the Cab. That boils down to both better handling and acceleration (and aerodynamics = high speed stablility). I am in the same boat. I am looking for a 2001 C2 Aero coupe.
As far as C2 vs C4, you need to decide if you want AWD or RWD.
Old Mar 1, 2006 | 04:56 PM
newport996's Avatar
newport996 is infamous around these partsnewport996 is infamous around these parts
Its all a personal decsison. The C2 coupe is the lightest, and has a performance edge on the C2 cab and C4's....BUT I have the C4 cab, with PSS9 suspension, bone stock motor...and it is a 0-60 car in under 5 seconds and will do every bit of 170+ mph....so the question is, how much performance you want? When you speak of better performance, you are talking fractions of a second, not seconds.....For instance, a C4 Cab 6 speed is faster than a C2 coupe tiptronic. C4's are more money and C4 cabs are even more money, probably the most expensive narrow body 996's.
Old Mar 1, 2006 | 05:45 PM
WyattH's Avatar
Exactly. The difference is small. And the transmission is a big factor.
Get whichever is more fun to drive!
Old Mar 2, 2006 | 11:31 AM
Miykl's Avatar
Miykl is infamous around these parts
test drive both c2 and c4 versions. The feel is very different.
tropicatango
Jun 8, 2025 01:00 PM
2lflat4
Nov 18, 2019 05:05 PM
Just Cruise
Aug 25, 2015 12:39 PM
Just Cruise
Aug 25, 2015 10:45 AM
JMon
Aug 21, 2015 08:20 AM
