Guys with 285/295 rear tires...
Old Jan 19, 2004 | 09:31 AM
NickS's Avatar
NickS is infamous around these parts
What tire pressure do you typically run? I've been running 40psi in mine and just noticed yesterday how worn the centers are now. They are very concave.
So I reduced the air pressure down to 37psi and now the car squirms a bit in the rear. Is this sidewall flex you think?
I'm running S-03's BTW.
Old Jan 19, 2004 | 12:58 PM
carbonissimo's Avatar
carbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud of
295's
I've got Michelin PS2's and run 44psi .
5000 miles and little wear, but very even.
Old Jan 19, 2004 | 08:22 PM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
37psi for street use is too low, I have run factory spec for street use and found the tires to wear as expected, I would raise your pressures.
Old Jan 20, 2004 | 04:25 PM
SennaSixty8's Avatar
2 wheeled Specialist
SennaSixty8 is infamous around these parts
Arrow wait a second!!
HOW wide are your wheels.....if they're too narrow for the tire, it causes it to BOW or essentially "point" the tire, causing it to wear quickly
Old Jan 21, 2004 | 05:58 AM
NickS's Avatar
Re: wait a second!!
I have 285/30-18 on 18x10
Old Jan 21, 2004 | 03:23 PM
bayarea jimmy's Avatar
bayarea jimmy is infamous around these parts
After some experimenting, I've settled on 35/38, PilotSport N1, C4S stock alignment, wheels & tires. 9300 miles, even wear.
By the way, 295 should be running on 11" wheels.
Old Jan 21, 2004 | 08:37 PM
Aron's Avatar
Aron is infamous around these parts
I normally run the stock 44psi in my PZero's (285/30/18) unless I have some desire for a smoother ride. Then I will drop to 40psi. Anything less than that and they feel squirmy to me (and I see shoulder wear). 9800 hard miles and the wear on the inner 3/4 is pretty even, although they're basically down to the wear bars now.
werkzrs
Apr 23, 2020 12:03 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
gulf gt
Aug 27, 2015 10:27 AM
rnl
Aug 26, 2015 02:36 PM
Lucid Moment
Aug 20, 2015 02:22 PM
