Options..need help please
Old Feb 17, 2004 | 01:05 PM
jnx's Avatar
jnx
jnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to behold
My salesman is thinking that the HI FI option #490 is not available with the PCM option #P16. When I configure it, it does not conflict. Does anyone know for sure? Does anyone have it in an 04? Thanks
Old Feb 17, 2004 | 02:07 PM
msindi's Avatar
They do conflict I believe...
Check the order guides here http://suncoastporsche.com/guides/index.html
Old Feb 18, 2004 | 02:58 PM
jtrichel's Avatar
jtrichel is infamous around these parts
i do not believe this is correct... you should have no problem ordering whatever stereo you want...independent of PSM
Old Feb 18, 2004 | 03:43 PM
ScottW's Avatar
ScottW is infamous around these parts
I vaguely remember reading somewhere that there are several versions of the CDR23 depending on which sound option you get. Some versions have amplification and some do not. I know the Bose option has an external amplifier and I thought the HiFi used internal (to the head unit) amplification. The order guides don't show a conflict, but maybe the PCM2 needs the external amplifier that you get with Bose.
Does any of that make sense?
-Scott
Old Feb 18, 2004 | 05:07 PM
jnx's Avatar
jnx
Thanks guy's, after your help, He saw where he made a mistake.
Old Feb 18, 2004 | 05:32 PM
SorTurbo's Avatar
SorTurbo is infamous around these parts
actually if you go to the PCNA website it tells you that ALL audio systems (BOSE, Hi-FI and stock) are compatible with the PCM system. I hope this is correct information because I ordered with the Hi-Fi...
