Need Help
Old Apr 21, 2007 | 04:06 PM
kimcheebowl's Avatar
kimcheebowl is infamous around these parts
Need Help
Found a nice 1999 C2.
What should I look or ask for before purchase.
Thanks!!
Old Apr 21, 2007 | 05:13 PM
Jurichar's Avatar
Jurichar is infamous around these parts
get a ppi
look for rms leaks
that should get you started till the experts chime up
Old Apr 21, 2007 | 05:24 PM
Thanks!
I'm NEW to this PPI and RMS ?
Is this leak down and compression test?
Old Apr 21, 2007 | 05:41 PM
Jurichar's Avatar
ppi = pre purchase inspection. take it to a porsche dealership and have them check everything out. They will charge about $300 and test things that you cant ie leak down and compression
RMS = rear main seal. Its a seal where the engine and transmission meet, it leaks....ALOT. Look under the car and see if there is oil in this area, if there is, you will probably need to have it replaced and your looking about ~$1000.
Old Apr 21, 2007 | 05:59 PM
Thanks!!
Dealer told that they won't do a leak down and compression test unless soemthing is wrong.
Old Apr 21, 2007 | 06:30 PM
Any place in San Diego area can do PPI?
Thanks!
