996tt spoiler 14mm hex bolt
Does anyone know where i can get 2 of the 14mm hex bolts thats located under a 996tt spoiler?
Here is a link https://www.6speedonline.com/forums/...e1417750307979 |
Or does anyone know the size and pitch of the hex bolt ?
I too am looking for a set of these adapter.
I am currently looking... I have tried dismantlers, dealership, sun-coast parts, etc. no luck
since there is no part no they cant find or order the part i am told i have to buy the wing blade to obtain the bolts... if you have any luck please let me know... best of luck... |
So i got the the thread pitch for the bolt:
m22x1.5 this is confirmed from a wing manufacturer. |
Amazon.com: Mercedes (55-91) Engine Oil Drain Plug (26mm) + Seal FEBI-BILSTEIN washer ring: Automotive
could you make this work? drill a hole and press in a dowel? |
Originally Posted by stilov
(Post 4314762)
Stainless and the right thread pitch....just need to order 1000 @ .80/each http://ouyao.en.alibaba.com/product/...Plug_Seal.html
Originally Posted by sshrum
(Post 4315615)
Here is my 5 minutes of research:
ALFA ROMEO 60507149 FORD 16993411 VW N10037103 https://www.rundtombilen.dk/images/b...%20-Seat-p.png This is closest match, made of bronze, do easy to modify and plant that pin, going across. |
And we are in business:
http://www.ebay.com/itm/161426040213 I suppose I could drill through this drain plug and across, for the cross pin. Since there are 10 pieces in this box, I might have extras.... |
I'd be down for 2 sets if you make um.
Mish...dbl-check you ebay link. Did you see the other photos...it's a square hole (I think-4 sides), not a allen. Not sure if the spoiler post would fit.
Center gets drilled out to 14mm, tightening would be done by outer hex, which is 31mm and serves as mounting surface as well.
5 Attachment(s)
So I think I got solution, not cheap, but one side is already done and the other side will be finished tomorrow.
With all tooling and cost of generic part from local pipefitting supply co., we are looking at $85 for two adapters. Sadly two hose fittings that I cut run me $30, of course, if I find generic part and make whole bunch, cost goes down drastically, but I do not think there is huge market for the widgets. Regardless, here is fruit of my rough labor, fits onto ram like a glove. |
