DIY: Removing stock 996TT spoiler
Old Dec 28, 2008 | 06:29 PM
M32's Avatar
M32
M32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond repute
I bought a TA style rear spoiler and installed it tonight.
Here are the tools you need:
14mm Hex Socket
Special spoiler removal tool (came with the TA spoiler when I bought it)
It's pretty simple and sorry for the really bad pics (just had my BB Curve and didn't have my camera).
Insert this special tool into a small hole in the cylinder of the spoiler piston (for lack of better word). I believe you turn clockwise (see VERY bad video I took) but try both ways to make sure. Once you turn it a little, it will pop right out.
This is what the top of the piston shaft looks like and you can see the grooves how the spoiler catches on.
Once the spoiler comes off, you will need to remove the "adaptor" off the oem spoiler.
Note the little metal bar that cuts through the middle of the hole, which is where you need to align it with the top of the shaft as you can see in this pic
Use the 14mm hex nut and remove it. Mine was pretty tight on there so be careful.
This is what it looks like removed.
That's it...go in reverse order and you're done.
Here's a video
http://www.youtube.com/watch?v=Gm7oEAjTRN8
Edwin
Old May 8, 2010 | 02:02 AM
Kevganzon's Avatar
Kevganzon is infamous around these parts
Great post! Thanks!
Old May 8, 2010 | 05:57 AM
landjet's Avatar
How come you had those spacers on the stock wing?
Old May 8, 2010 | 08:00 AM
PrecisionPorsch's Avatar
PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !
Larry,
It wasn't on the stock wing... I just took the video as I was taking off the TA wing.
Edwin
Old Dec 20, 2010 | 02:02 PM
jerryt's Avatar
jerryt is infamous around these parts
Thanks this was a GREAT HELP
Old Dec 20, 2010 | 02:15 PM
02TurboTip's Avatar
02TurboTip is infamous around these parts
great write up... looks like a simple enough change.
Old Dec 20, 2010 | 04:14 PM
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
DIY posts are always greatly appreciated!
Old Jan 2, 2011 | 05:32 PM
Scottslaw's Avatar
Scottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond repute
Hey Edwin...where can you buy those spacers? I assume they are there so that the aftermarket wing does not contact the spoiler base when the blade is in the down position, right? Hard to install?
Old Jan 2, 2011 | 05:34 PM
Almo's Avatar
Almo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant future
Anyone know where one can buy the spoiler tool?
Old Jan 2, 2011 | 05:43 PM
NOLA911's Avatar
NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !
I did mine without a spoiler tool. I from a recommendation here used a rubber belt style oil filter wrench. It literally took 30 seconds for each side once I figured which way to turn it.
Old Jan 2, 2011 | 07:37 PM
jpflip's Avatar
http://www.maxspeed-motorsports.com/...oval_Tool.html
Old Apr 11, 2013 | 08:12 PM
BMiller33's Avatar
BMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond repute
Bringing it back to life as I need to remove mine to fill the hydraulic cylinder, damn bango bolt washers leaking on driver's side.
http://www.samstagsales.com/Porsche.htm
AMF 54924
Old Apr 12, 2013 | 01:53 PM
BMiller33's Avatar
I CAREFULLY wrapped my channel lock pliers and easily twisted the shaft clockwise and the spoiler disconnected. See image below.
Anyone refilled a cylinder? I removed mine and turned it upside down but only a few drops went in, not even 1ml (they call for 5). The piston is retracted as the manual states. Any help appreciated. Thanks.
Old Apr 22, 2013 | 08:50 PM
B8_RDC's Avatar
B8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond repute
Draft beer faucet wrench works. Super cheap too ~$4.
http://morebeer.com/products/faucet-...html?site_id=7
Old Oct 22, 2013 | 05:25 AM
Hdimashk's Avatar
Hdimashk has a spectacular aura aboutHdimashk has a spectacular aura about
So basically I just grab each side turn them till the spoiler pops off and then I put the new spoiler on and screw it bck in ? Thats it?
