traction control not turning off?
Old Jan 2, 2008 | 03:39 PM
QTR TT's Avatar
QTR TT is infamous around these parts
does the PSM realy turn off when you press it? i turned it off today and came out of a turn and floored it to get the car to loose traction and it still came on. i lost traction for a second then i felt a loss in power until the car got straight, then the boost came back again. I know that with BMW's the traction control stays on even after de-activating it, unless you press and hold the button for more than 5 seconds. is it the same with the porsche?
Old Jan 2, 2008 | 04:36 PM
jhbrennan's Avatar
Not sure this answers your question. This is from the 997 Owner's manual - I'm sure there's something similar in the TT manual, I just don't have it handy. I don't think PSM is really ever "off" on the TT - but in reading about the GT2, I think you can turn everything off on that car.
File Type: pdf
Old Jan 2, 2008 | 08:44 PM
crd's Avatar
crd
crd is infamous around these parts
jhb is right. On the 997TT, the PSM cannot be totally disabled. With the PSM switched off, the stabilizing adjustments are just made later during an unstable situation, and the parameters to define "instability" are more liberal.
The GT2, OTOH, can have the PSM totally disabled and it will not re-engage until the driver re-activates the PSM system intentionally.
Old Jan 3, 2008 | 01:51 AM
haudimal's Avatar
haudimal is infamous around these parts
Sorry, but this is not correct, you describe the behavior in sport mode, where PSM is more liberal. But if you switch PSM off being in Sport mode itīs off until BOTH ABS sensors on your front wheels detect a locking wheel. PSM off in normal PASM Mode will be activated if ONE of your ABS sensors detect a locking wheel.
Hope you understand what iīm trying to say, this info is from the 9977TT technical info and itīs written in german
I can assure that PSM off means off, i experienced this on a drift event and a lot of funny snow days.
Old Jan 3, 2008 | 02:11 AM
QTR TT's Avatar
mine doesn't drift at all, maybe because its a Tip.
I've put it in situations where the car should have gone sideways but it would barely skid then the PSM kicks in. maybe I'll have to wait for some rain to test this again
Old Jan 3, 2008 | 02:37 AM
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
it turn off when u press the traction button and tick the hand break in the first tick ;p u gonna have it totally disabled just like the GT2 have fun and TC ...
Old Jan 3, 2008 | 02:59 AM
QTR TT's Avatar
one tick on the hand break would not activate the breaks right?
thanks bro
Old Jan 3, 2008 | 03:04 AM
haudimal's Avatar
No, the problem is not tiptronic, the problem is maybe you
I have a tip and once it starts to drift itīs quite a *****. Donīt wanna be your grandpa but you should not try your first drifts on public roads
driftproovepicture, not a good shot but i think the driver is a nice guy
Old Jan 3, 2008 | 04:05 AM
yalmutawa's Avatar
it wont effect it yes and it will be a super drift car
Old Jan 3, 2008 | 06:52 AM
Mowateriology's Avatar
Mowateriology is infamous around these partsMowateriology is infamous around these parts
got a vid?
Old Jan 3, 2008 | 10:45 AM
AvusRS6's Avatar
AvusRS6 is infamous around these partsAvusRS6 is infamous around these parts
I got my car to do a 360 with traction off...it was scary as ****. So I would agree that the Traction off in Sport Mode really means off as it did not try to assist in any way for me.
Old Jan 3, 2008 | 02:49 PM
QTR TT's Avatar
I'm not new to drifting . i used to have a 400 hp RX7 and that thing would go sideways anytime you even think about turning lool . i had some scary moments with it.
i guess i'm not used to the traction of a 4WD car.
Old Jan 3, 2008 | 03:49 PM
haudimal's Avatar
yepp, thatīs a real different story. Beside the PSM, which you can switch off, there is the intelligent 4wheel drive in the 997TT, which donīt want you to drift. As soon as your back wheels start slipping it sends more torque to your front wheel. You have to be very rude to your car on a dry surface to keep it drifting, what is not such a big problem because of the pure power of your engine.
Itīs really not that hard to keep the car in a controlled drift, but the big difference compared to a RWD car is the fact, that you are getting faster and faster because of the extra grip from your front tires. With a RWD car, once you start your drift, you can keep it at the same speed, but with the 997TT you will raise your speed and need more space than you will probably have on a public road.
I donīt talk about a drift beginning quite after the apex or at the end of a curve, which is always doable for a braveheart, but rather from a drift starting at the beginning of a curve and i give you (and me) 9 out 10 to end it in the field.
Old Jan 3, 2008 | 04:30 PM
yalmutawa's Avatar
not yet loool cause i use to use both hands to handle it when i tick the hand breaks hahahahha :>
Old Jan 3, 2008 | 06:17 PM
cayenne_ksa's Avatar
cayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond repute
would you give more info about that one tick hand break
do you do it with PSM on or off? sprot mode ON or OFF
it seems little bit iterested. can't wait to try it tomorrow .
