Ever use one of these before?
Old Mar 18, 2008 | 09:09 AM
K-80's Avatar
K-80 is infamous around these parts
http://www.northerntool.com/webapp/w...3340_200323340
Looks like a nice system and was wondering if anyone has used it?
Old Mar 18, 2008 | 07:20 PM
mad_al's Avatar
mad_al is infamous around these parts
A buddy uses one of these and he is satisfied with it, but fyi it wont suck out all the oil.
Old Mar 19, 2008 | 03:30 AM
K-80's Avatar
Thanks, I was told this is the way may high end cars oil is changed....MB techs use this method....just wanted to know if any forum members are using one.
Old Mar 19, 2008 | 06:28 PM
KandyRedCoi's Avatar
KandyRedCoi is infamous around these parts
my buddy that works on cars a lot said that he wouldnt mind it if he can afford it, so im guessing its good!
no 1st hand experience tho
Old Mar 19, 2008 | 09:15 PM
gradyex's Avatar
gradyex is infamous around these partsgradyex is infamous around these parts
I usually get 8.5 quarts or more out of mine (I dont drain the turbos) using the regular method. That extractor has a maximum of 6 quarts at a time so you might have to empty it and give it another go? The more oil you can extract the better and don't forget the filter (its right on top of the engine and very simple to change using the right tool, torque it at 19lbs after replacing the filter element and "O" ring). Very important to measure what you take out and put back the exact amount or you will overfill it (thats a no no). Good luck.
Old Mar 20, 2008 | 05:22 AM
K-80's Avatar
Unhappy
The extractor I posted the link too has a 8 gallon maximum....thanks for the reply
