TPMS Accuracy?
Old Oct 11, 2008 | 09:51 AM
leadfoot's Avatar
leadfoot is infamous around these parts
TPMS Accuracy?
My TPMS is always 3to 4 pounds less then the real tire pressure.I have checked it with different gauges and it is always 3to 4 psi less.Is that normal and can it be adjusted or do we just deal with it.
Old Oct 11, 2008 | 09:54 AM
bbywu's Avatar
It's normal. I don't think there's a fix. IMHO, the only thing TPMS saves you is accidentally driving on a flat tire that you were unaware of.
Old Oct 11, 2008 | 12:45 PM
raiyu's Avatar
raiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to behold
Its normal, if you read your temperature in the morning when your tires are cold, and then check the TPMS the difference is usually the same. So if its -3PSI it will stay that way as they heat up.
Useful for the track, when I see 34-35 PSI on the rear I know my car is gonna be loose, I bleed after every session, but this way I know immediately in car.
Old Oct 11, 2008 | 08:20 PM
SamboTT@ByDesign's Avatar
+1. My favorite is when you are only 1-2 lbs down and it says you are low.
Old Oct 12, 2008 | 12:13 PM
freshtrax's Avatar
freshtrax is infamous around these parts
leadfoot- did you change the wheels? if so, sometimes the installer puts the TPMS sensor back in incorrectly. I think that issue was diagnosed and discussed a few months ago in a thread here too.
need4speedmotors
996 Turbo Vendor Classifieds
Jan 12, 2016 05:41 PM
C5tt
Oct 24, 2015 07:35 PM
freddiemac
Oct 7, 2015 11:05 AM
miken168
Oct 6, 2015 09:21 AM
need4speedmotors
997 Turbo Vendor Classifieds
Sep 28, 2015 04:47 PM
