ASR Engineering Air Intake Kit + Charge Pipe
Old Oct 13, 2008 | 05:16 AM
997ttguru's Avatar
997ttguru is a name known to all997ttguru is a name known to all997ttguru is a name known to all997ttguru is a name known to all997ttguru is a name known to all997ttguru is a name known to all
Do we need a new program for ecu if we install those? Because of the new air flow etc...
And what should be the expected gain?
Thanks..
Old Oct 13, 2008 | 07:01 AM
997 GT3 RS/TT's Avatar
997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute
do you have some pictures?
Old Oct 13, 2008 | 08:37 AM
ASR Engineering's Avatar
ASR Engineering is infamous around these parts
An ecu flash is not required for our intake and hardpipe kit. As far as the gains are concerned, we've dyno tested the intake system to produce an additional 24whp and 26wtq. The 997TT’s stock plastic chargepipe causes a large amount of airflow restriction in the upper rpm’s of the powerband causing a premature drop off in power. We are the first and only company to offer you a tapered 2.5” to 3” aluminum chargepipe with a 4” collector. This pipe is not only lighter in weight than the factory plastic chargepipe, but also comes with billet cnc finished ends and map sensor flange for a factory finished fitment. I've attached a pic of the parts installed.
If you have any further questions, please feel free to contact us @ 786-430-4431 or 786-258-0009 and either myself or someone from our staff will be more than happy to assist you.
Old Oct 13, 2008 | 09:54 AM
JbbnTrejo's Avatar
JbbnTrejo is infamous around these parts
nos?
what nos shot you running in that car above?
Old Oct 13, 2008 | 10:32 AM
997ttguru's Avatar
No I don't, sorry.
Old Oct 13, 2008 | 10:35 AM
997ttguru's Avatar
Thanks for the info.
Old Oct 13, 2008 | 01:44 PM
WhiteKnight's Avatar
WhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to behold
Can we use the charge pipe kit with stock airbox ?
Old Oct 13, 2008 | 07:42 PM
360Forged's Avatar
360Forged has a reputation beyond repute360Forged has a reputation beyond repute360Forged has a reputation beyond repute360Forged has a reputation beyond repute360Forged has a reputation beyond repute360Forged has a reputation beyond repute360Forged has a reputation beyond repute360Forged has a reputation beyond repute360Forged has a reputation beyond repute360Forged has a reputation beyond repute360Forged has a reputation beyond repute
125 shot + methanol injection! Thanks Abid!!!
Old Oct 13, 2008 | 09:32 PM
lintc0532's Avatar
lintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond repute
So there is a BLOW OFF VALUE come with the charge pipe?Does it make any "push" sound?If so I interested.
Old Oct 13, 2008 | 11:06 PM
gxlex's Avatar
gxlex is infamous around these partsgxlex is infamous around these parts
You guys ever check your PM box? I sent a PM over a month ago about this setup and still no one from ASR reply yet.
Old Oct 14, 2008 | 12:10 AM
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
subscribed
Old Oct 14, 2008 | 02:36 PM
Our apologies, a mistake was made as we thought we responded to to your pm. We have resolved this and sent you a response. Again, sorry for the inconvenience.
Old Oct 14, 2008 | 02:45 PM
The chargepipe can only work with aftermarket intake since the factory box hinders the fitment of the larger diameter tubing.
Old Oct 14, 2008 | 02:51 PM
Yes, the blow-off valve does blow off to the atmosphere fairly loud. Also, you will not have any issues with idling as most valves do with unmetered air.
When we install this valve, we block off the factory valves located on the turbos.
Old Oct 15, 2008 | 06:00 AM
golfguy's Avatar
golfguy is infamous around these parts
can you post a dyno chart? i didn't find one on your website.
