How to Change Your Brake Rotors at Home
Ingore this, someone mentioned it already...
997 TT caliper is also monoblock:
of each monobloc caliper—a
A single
block of aluminum forms the body
design that is extremely rigid,
robust and lightweight to further
reduce unsprung massrobust and lightweight to further
Exactly the OEM rotors do fail easier. These are much more durable. Because of the design of the 2pc, you will have better pad wear, the rotor more on a center line with the floating design, and with the top pics posted above, you will better heat dissipation.
