This car is incredible...
Old Jan 7, 2009 | 12:34 AM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Don't feel bad. Look at the Ruf RT12...they don't have that stupid zit on the dashboard. Why have a "sport" button when you can program the ECU to be in "sport" mode all the time? <!-- google_ad_section_end -->
Old Jan 7, 2009 | 12:52 AM
TTdude's Avatar
Ooops, sorry Bob. My touch pad is too sensitive and the reply just took off on me before I could finish. I just wanted to say thanks for the info and am glad that my thinking wasn't totally off when I ordered the car.
[No worries. Like Bob says, you can bypass all that with a good ECU tune. I just thought that if you had the sport chrono and was only getting 13 psi, that would have been an issue. Which ECU did you get?<!-- google_ad_section_end -->]
I ended up going with EVOMSit simply because I was attracted to their switching technology. I want to be able run different octane levels and not have to worry about whether I'm in the right subset of programs for optimal performance.
Old Jan 7, 2009 | 07:28 AM
nevert00fast's Avatar
nevert00fast is infamous around these partsnevert00fast is infamous around these parts
Sorry for being a noob, but can you explain this a little more? I was under the impression that with the EVO tune you can't switch between differnt octanes, except for if you ask them to program the Sport button to run a higher octane? Is there a module that comes with the EVO tune that will allow you change between different fuel/boost maps?
Old Jan 7, 2009 | 12:29 PM
TTdude's Avatar
No apologies necessary! I'm a novice at this too but I'll give you my 2 cents and at the same time reveal my ignorance. Fortunately, there are enough experts here that can correct anything I say that needs correcting. The EVOMSit program does not utilize a hand held module if that's what you mean. It uses knock sensor and switching technology (like stock) to regulate the various maps for octane ranges roughly between 91-100. Your ECU will be tuned depending on the mods you have. There are different tuning parameters for just an ECU tune (keeping everything else stock) versus an ECU tune with an exhaust upgrade, etc... This keeps the engine safe. I also had very good experiences in communicating with the Evom group. Even Todd Z. (the president) took time to answer my sophomoric questions. In all, I felt comfortable entrusting my ingorance (and of course my car) to those who know.
Old Jan 7, 2009 | 02:40 PM
Thanks for the reply. So what happens if I put in 100 oct. in the car when the tune is for 93? I'm assuming the car will change to the map that's suitable for 100 oct., but will the car actually make more power? I doubt it will unless it knows there's 100 oct. in it somehow and raise the boost. My local tuner told me EVOMit has an option that if you turn on sports mode, it will go into 100 oct. mode and makes more HP by raising the boost even more.
Old Jan 7, 2009 | 03:01 PM
TTdude's Avatar
You might want to contact EVOM to get a more technical explanation. My understanding is the knock sensors control the maps. So you're right that that ECU does not know, per se, that you've just put 100 octane in but will detect the higher octane via the knock sensors and adjust accordingly. Maybe there is a slight delay compared to the hand held device which you can directly plug in the octane leve. I don't know. Stephen from IA sold me the upgrade and he is a wealth of knowledge. Basically, these guys are custom tuners and can program whatever they want into your ECU. I don't have a sport button but they can make a car without a button do everything a car with a "button" can do (and more), but as Bob would say, without the "zit" on the dashboard.
Old Jan 7, 2009 | 03:42 PM
johnww's Avatar
johnww is just really nicejohnww is just really nicejohnww is just really nicejohnww is just really nice
Originally Posted by nyamg
I'm on the highway tonight and I'm in 6th, thats right 6th, sport chrono on and I''m doing 80 I nail it, not to the floor but about half way...boost kicks in and I'm gone literally gone, I look down and I'm at 130 within seconds, INCREDIBLE.. thats all I have to say. This car pulls 6th like most sports cars pull 3rd.
Interesting post and answers. Speeds at +80 ( @70 mph posted limit), depending on actual tt-speed can give driver 4-6 points (i.e., up to 90m/h) and >>95m/h can lead to loss of license, jail time and even possible impounding turbo. However, when inquiring earlier about tools police are using more in monitoring such high speeds, that is. laser vs radar (substance that could really save a tt-butt), no comments were made. Again, interesting to see which posts are important and which posts remain wasted bits.
Old Jan 7, 2009 | 06:44 PM
turbonator's Avatar
turbonator is infamous around these parts
Luck of the draw as they say. Matt Dillon was arrested doing 106 in a 95 zone in VT last week.
Old Jan 7, 2009 | 09:31 PM
substance's Avatar
substance has much to be proud ofsubstance has much to be proud ofsubstance has much to be proud ofsubstance has much to be proud ofsubstance has much to be proud ofsubstance has much to be proud ofsubstance has much to be proud ofsubstance has much to be proud of
get the 700 HP evo kit
Old Jan 8, 2009 | 10:05 AM
Vic55's Avatar
Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !
I have the gauge on bar, I believe it got up to around .9 bar, I could definetly be wrong about that though.... somebody else who knows more should chime in here.
.9 bar seems low for 6th gear... you should be seeing 1.1 or 1.2. It also depends on the climate.
Old Jan 8, 2009 | 01:08 PM
nyamg's Avatar
nyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud of
Is the gauge supposed to stay at 1.1 or 1.2 bar for more than a second when the car is at WOT, or does it hit 1.2 bar and immediatly fall back????
Old Jan 8, 2009 | 01:47 PM
Vic55's Avatar
Mine holds a steady 1.2 bar all the way up and beyond 160 for as long as I am at WOT and I have a tip(I have never run past the 15 second boost time). I am guessing that yours should be no different in 6th. Changing your diverter valves will improve the hold characteristics. But if you are peaking at .9 bar in 6th that might be a little weak IMO.
When I had a small vacuum leak with my plenum, the boost would spike in final gear at 1.2 but then would settle down at .9 bar within a few seconds and I knew I had an issue.
Old Jan 8, 2009 | 10:36 PM
nyamg's Avatar
I think I might have a leak then, I don't think my car is staying at 1.2 bar steady. I don't understand why Porsche couldn't leave the extra power there all the time like the M cars from BMW, sport on means extra power all the time, as opposed to this 15 sec sh*t.... just my .02
Old Jan 9, 2009 | 06:15 AM
Warranty.
Old Jan 9, 2009 | 08:31 AM
summoboy's Avatar
summoboy is just really nicesummoboy is just really nicesummoboy is just really nicesummoboy is just really nicesummoboy is just really nice
I want one - TT.
