Silver Turbo with Brushed Wheels - What You Think?
I may want another set if i can find some Track 20's.
i would probably want either textured black or silver...
I will run into aligment issues and corner balancing again... i need to stay with 20's. your fault i ended up here in the first place!
If you put 19's on for the track you wont have to realign it each time. Ideally you are keeping it close to the same overall diameter. For the track you could use the factory camber adjustment up top and give yourself some more negative, but you would be fine. I dont think anyone has race rubber in 20
