Should I put Michelin Cup tires on Kinesis F110 rims.
Old Feb 1, 2009 | 10:29 AM
jnixon's Avatar
Awaiting Email Confirmation
jnixon is infamous around these parts
I did a search and did not find any negative answers. Most people I have asked have steered me away from the Cup sport tires. I am thinking about a second set of Kinesis F110 rims painted in satin black and wanted to get a tire that is different that what I already own. I have Potenza's and PS2s already.
I was planning on putting the tire on a kinesis F110 painted in satin black and use them for the track or light street use in the summer. I would like to hear any negatives about going with this tire.
Old Feb 1, 2009 | 10:37 AM
TT Surgeon's Avatar
Go for it!
Old Feb 1, 2009 | 10:48 AM
raiyu's Avatar
raiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to behold
There are a few downsides to cups.
1) They hydroplane very easily (although I think less than the Toyo R888) so you will need to go slower in the rain (50mph where you would easily be doing 75mph before).
2) They are sensitive to temperature. You are in Texas so I dont know how cold it gets but when its 30-45 the tires feel like rocks even with low PSI. These really need a warm ambient temperature otherwise they are no better (if not worse) than other performance tires.
3) They have a lot less tread than regular tires. You want to make sure that you have a good alignment, even if you arent tracking the car, because you will eat through the insides very fast if you have too much negative camber and you'll be replacing them very fast.
4) They are very sensitive to PSI changes on the track. You will want them around 32F and 34R when hot (check your pressure after each session and bleed them). Even a 1 PSI variation can make a huge difference as anything above 35R and the car will become very sloppy. If you notice that you are losing traction near the end of your session, especially under breaking check your in-car PSI monitor, its off by a few PSI but you can determine how much the PSI has risen since you drove out and you'll probably see that its way too high. On my car the PSI reads about 29/31 and thats about 32/34 in the tires.
Positives:
They are fantastic tires with a lot of feedback, as long as you watch out for the points above you will have no problems with them. Personally I think they are overkill unless you track the car regularly, otherwise you may not notice much of a difference between them and the PS2s and you will need to be more mindful of the weather.
Old Feb 1, 2009 | 10:51 AM
jnixon's Avatar
****, the tires seems overly sensitive. It looks like I would be better off with PS2s. Any other tire suggestion.
Old Feb 1, 2009 | 10:56 AM
03-turbo911's Avatar
Senior Member
The Pirelli Corsa is another alternative to the Michelin Cups. It's better in the rain or damp conditions. I have to agree to raiyu though. These are at best a comprmise, not as good as slicks and not as good for everyday use as the PS2.
Old Feb 1, 2009 | 11:22 AM
cannga's Avatar
Fantastic & helpful report. Thanks.
2) They are sensitive....
Old Feb 1, 2009 | 12:12 PM
David9962000's Avatar
David9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond repute
Nice wheel, how about the Pirelli Corsa?
Old Feb 1, 2009 | 03:49 PM
TurboLover's Avatar
TurboLover has a spectacular aura aboutTurboLover has a spectacular aura aboutTurboLover has a spectacular aura about
They'd make a great combo just be sure to stay out of the rain and snow.
Old Feb 1, 2009 | 05:43 PM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
I have had no trouble with the N 0 Porsche spec sport cup tires on the street.
Old Feb 1, 2009 | 06:01 PM
Frissen's Avatar
Frissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud of
I have tried the cups on the street and they are wondeful under dry conditions, really responsive and even comfortable... I have no clue under rainy conditions...
Old Feb 1, 2009 | 06:06 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Frissen
When is Luis going to invite up to Houson? I think you will like the MSR track.
Old Feb 1, 2009 | 06:22 PM
TurboLover's Avatar
In rainy conditions it's like driving on ice...
Old Feb 1, 2009 | 08:09 PM
damon@tirerack's Avatar
Moderator
Everything said has been very well put. I'd start with PS2 and go up to cups from there. This time of year isn't the time to be "learning" Cups.
Please give me a call if I can help!
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Feb 1, 2009 | 08:59 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
John,
I run Cups on the street without any adverse effects. They are not the real cups, more like PS3's. I think you would be very happy with them, and they weight 2lbs less per corner than the PS2's
Old Feb 1, 2009 | 10:00 PM
TT Surgeon's Avatar
Agree with Eclou, these are not old school cups, they are harder and have an extra rain groove cut into them. I have driven mine in the rain numerous times, something I could never do with my old (real) cups.
