20" wheels air pressure
So I have a similar question on my 07 TT. I'm running 245-30 and 325-25 on 20" wheels. Based on your recommendation I should be at 38 and 46 psi? Seems high.
Hopefully tirerack crew can chime in.
What about semi slick tires ??? I have Pirelli Pzero corsa II system (the new one ) I think 3+ psi for rear wheels is WAY too high...
I use 2.2 cold for front and 2.7 cold for rear... Too low ??? If i see more than 3.0 back when is hot the car is not so stable...
Guys so I still have some questions on this topic. Porsche recommends 36 and 44 psi at cold, so on average I see a 2-3 PSI shift from cold to hot. Factoring in this shift and running the recommend +2 psi for 20" wheels would put my hot temp PSI at 41 front and 49 rear, with a max PSI of 50 for the tire this does not seem right. Keep in mind all of my measurements are coming from TPMS. Thanks.
Jul 29, 2019 11:13 AM
PenguiN
Sep 15, 2015 11:44 AM
