Knocking sound in front??
Thanks, So this is common with lowering springs? I did not notice any noise until I put about 2000 miles on the car then it started knocking. The installer said that it could be the perch as well and also stated that it could also be the spring compressing and knocking when the coils rub together. He says the reason the noise did not occur initially is because there was a plastic type coating on the spring that wears off then the noise starts. I figured I would get other opinions on the matter.....I am very annoyed by the sound and may consider coilovers if they DO NOT make the knock sound.
Enemy
Nov 10, 2015 08:01 AM
