Suspension preferences?
Old Oct 28, 2009 | 11:47 AM
cayenne_ksa's Avatar
cayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond repute
Originally Posted by GotBoost?
That is probably a setup and alignment issue. Having a coilover setup that has rebound and compression adjustability opens up a can of worms. You really need a tuner shop that knows how to setup a suspension in order to realize the full potential of your KW's. Just installing them and doing a quick alignment is not the answer. The rebound/compression/alignment/sway bar setting combination has to be right to your liking. Not one setup is right for everyone. Everybody has a different driving style and your shop needs to be able to cater to that. I suggest finding a real suspension expert in your area to sort out the kinks for you.
the problems is no one is aware of what they are doing even the dealer . I know a lot more than what they know. I'm really hoeing to find someone with KW V3 installed on his 997TT and ask him about hes set up or setting. As I said I'm sure they are really good suspension but need the right guy to set them up
Old Oct 28, 2009 | 11:51 AM
GotBoost?'s Avatar
GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !
Your dealer is the last place you want to setup your suspension. You should ship the car to Cali and have it done right by one of the shops here. Sharwerks, BBI, RSS, etc...
Old Oct 28, 2009 | 02:03 PM
the turbo is in Saudi. I was hoping that I can take it to RUF center in Bahrain but they closed their facilities over there.
Old Oct 28, 2009 | 05:22 PM
GotBoost?'s Avatar
oops. I thought it was in Denver...
Old Oct 28, 2009 | 07:16 PM
cannga's Avatar
I got KW V3 on my TT but I couldn't really enjoy them the way been advertised. I feel like there is some thing wrong with mine. comparing my TT to stock GT2 the GT2 feels a lot better and the steering response is better too.
Abdullah,
I agree with Gotboost. You need to have the installation and alignment checked.
I have driven both GT2 and Turbo. Once you have a stiffer coilover and make the appropriate alignment (more specifically more front negative camber, and a little front toe out), the gap should narrow.
Of course it does NOT make the Turbo a GT2, but it does turn it into a completely better and more "athletic" car, much closer to GT2 than stock.
1. Do you know what your front camber setting is?
2. If not, ask the dealer to give you a print-out of the alignment settings and post it here. We might be able to help.
KW (and JRZ & Moton) are all very good suspension systems. It should not feel that bad.
Old Oct 30, 2009 | 01:52 AM
cdragos's Avatar
cdragos is infamous around these parts
Original is perfect for street use, and mild street racing. I've had KW2 and it almoust broke all my theets. And no, I wasn't offroading)
danyoP4S
Sep 30, 2021 05:06 AM
Jul 29, 2019 11:13 AM
Feelgood MD
Mar 24, 2016 09:35 AM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
