20 inch tire settings
Old Jan 20, 2010 | 01:50 PM
dg123's Avatar
dg123 has a spectacular aura aboutdg123 has a spectacular aura about
Question 20 inch tire settings
was wondering if a 325 25 20 can be used w a 20x11 rear set up ?rims are champions rg5 rims? fronts are 8.5's
Old Jan 20, 2010 | 02:23 PM
GotBoost?'s Avatar
GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !
I don't think so. 325/25/20 is for 20X12 wheels. I think it will be too wide for the 20X11. I think 315 is the widest you can go for a 20X11 size wheel.
Old Jan 20, 2010 | 02:53 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
But you don't want to run 315's with the (known) available sectional widths or you'll destroy your differential.
https://www.6speedonline.com/forums/...15s-rears.html
Old Jan 20, 2010 | 02:55 PM
dg123's Avatar
thanks..i will stick with the ps2's in a 305 25 20...
Old Jan 20, 2010 | 03:13 PM
GotBoost?'s Avatar
You are correct, but It's not the width 315 that messes with the differentials. It's the fact that there is no tire size for the front that can keep the diameter within a certain spec of the rear tires that will screw with the diffs. Kind of goofy...
Old Jan 21, 2010 | 09:01 AM
bonehead's Avatar
Oops. Yes. Thanks for the clarification/correction GB. Available section heights (not width, duh!) for the fronts are the problemo.
oufan2929
Nov 8, 2015 08:26 PM
L.A.P.
Oct 19, 2015 10:01 PM
turbotuner20v
Sep 11, 2015 12:02 PM
The Oss
Aug 24, 2015 08:19 PM
L.A.P.
Aug 23, 2015 11:48 PM
