Rumour Mobil 1 to be replaced as OEM supplier
Old Mar 14, 2010 | 11:59 AM
ruf_turbo's Avatar
ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !
Originally Posted by HUMMM 3
I was told that many of the synthetics sold in this country, including Mobil 1 no longer have certain additives by government mandate. Don't know if that is the "Zn and P" you refer to. My mechanic uses German made Lubri Moly synthetic, which still has all the additives that were removed from Mobil 1, and it is Porsche approved.
It would seem very unlikely that if the government mandated certain additives out of Mobil 1, they are not going to let those same additives in other oils be imported. Make sense?
Old Mar 14, 2010 | 12:45 PM
slawek's Avatar
slawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond repute
Originally Posted by ruf_turbo
Shell has been the prescribed oil in Ferrari's for years.
<OWhen I had my 01 360 Modena years back my dealer in Spring Valley
recommended Castrol TWS oil
Old Mar 14, 2010 | 01:05 PM
PT Doc's Avatar
PT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond repute
Could it have been the removal of the mandate? Thus allowing oil manufacturers to make their own decisions.
Otherwise, if it was mandate to remove those elements, then a Euro brand might just get through a loophole.
Can anyone provide a solid source that points to the + effects of having these elements in the oil?
Old Mar 14, 2010 | 01:56 PM
HUMMM 3's Avatar
HUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud of
No, but I've been assured by others that it is the case in several available European oils. In any event I've only used Porsche approved oil, so I'm not going to worry about it.
Old Mar 14, 2010 | 05:43 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
Motul 8100 is another Porsche approved fill in 5w40
Old Mar 14, 2010 | 10:05 PM
Frissen's Avatar
Frissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud of
Porsche changed the coolant so its no surprise now the oil, specially counting the now belong to VW... I will continue to use Mobil for the time being...
Old Mar 14, 2010 | 10:26 PM
OldGuy's Avatar
OldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond repute
Most modern synthetics are good, and if you change them alot then any good synthetic is going to be good. Saying that I use Mobil and only Chevron gas.
Old Mar 14, 2010 | 11:18 PM
BumWine's Avatar
BumWine is infamous around these parts
Mobil1 seriously sucks. Their 30 weights aren't made in the same factory as their 15w50 and 5w20 oils, and the 30 weights aren't true synthetics. This means 10w30, 5w30, etc. I have seen more motors fail via rod-knock using Mobil1 than with other 'high performance' oils. Do the research yourself and you'll find similar results on websites like Bob Is the Oil Guy. Its absolutely absurd how WELL marketing works. "But Porsche say they're the best!!" I've never read a single bad review on Castrol Syntec from people who actually do oil testing. IMO its second only to oils like Motul and Amsoil, both of which I hold in utmost regards. Porsche switching to Castrol from Mobil1 is a good step forward.
Sure, a manufacturer does engineer a motor to use an x-weight x-brand oil, but I let the tests of those oils speak louder than what a manufacturer recommends. Its not just engineering, but also marketing. If a manufacturer has a deal with Mobil1 for instance, Mobil1 is going to pay them to use their oil during R&D of a specific engine. My LS6 says MOBIL1 on the oil fill cap, and I only have used Castrol, Amsoil, or (when available) Motul, usually a 10w40.
Since people are also posting what kind of gas they prefer, I try to stay on a strict diet of 93 octane Shell. Chevron when the nearest Shell is out of range, in which case I only fill up a few gallons.
Jun 10, 2017 07:45 PM
SharkyShark20
Sep 19, 2015 09:54 PM
